200 Series Icon stage 5 hybrid lift
You will know once you have it apart. Because if they don't move freely they are seized. A really s***ty design in my view.
Location for the switch pro.
what tire and size is the owner planning on running?
The seizing problem lies with the lack of a coating on the rubber control arm bushings inner steel sleeve. A little water in there and it can lock/rust tight to the bolts that pass through.
whats the plan is to keep the tire from eating the fender lip when flexing.
That's the main reason I didn't go tundra arms. I run the same 35's so I'm really curious
Thanks
Thanks
I'll take some pics of what we cut. We are also adding some bigger bump stops.
Timbren SES are what I'm running (f/r) if you're still in research mode. Thanks for the reply looking forward to seeing where the cutting takes place.
I also will be following this closely as I would love to run 35's at some point but with my 18x9 inch wheels with 20mm offset I am in a similar ballpark to you and I'm a bit concerned about the "tuck". Please post up pics of where you have cut when you get a chance and if you could also post some pics of the bump stops you use and the rig flexing that would be outstanding! thanks,
Lack of lubrication. From what we can tell. The first one was a really clean 2011. This one we soaked it for two weeks daily and they still had to be cut off. So just for you guys out there who are planning on taking your lca's off. Make sure you buy ALL new hardware before you attempt it. And plan 4-6 hrs of cutting
Trollhole,
Is it possible to slip a sawzall blade in there and cut the cam bolts or did you have to actually cut the top and bottom of the LCA to get it to come out? I'm planning the swap - and am anticipating this issue rearing its ugly head...
Or could you use another cam bolt insert as a sort of "punch" to knock out the existing seized bolt? If so I can send the ones I pulled and replaced w/ SPC version.
Thanks @Mogwai I appreciate the offer and will take you up on it! I also ordered the SPC bolts but certainly don't want to use the new ones as a punch to knock out the old. But my guess is that @Trollhole would have done something like that instead of spending so much time cutting....??
I'm not really understanding yet how exactly they are seized - but dang - if a professional took 4-6 hours of cutting to get those suckers off, then I should plan for a lot longer! :(
Maybe the bolt was seized in too. That earlier pic was of my clean side. The other came out fine but you can see how bad the bolt is, and the insert is actually seized to the washer on the other side (this is where I thought using the old insert would help).
Ugh....I need to get mentally prepared for this to get FUBAR'd right away. I appreciate the photos!
Cam you start pre-applying lubricant/penetrating oil.
Kroil, break free, liquid wrench
Pb blaster.
Pb blaster.
Oh I will! I've already started the kroil treatments.....I went through this with the KDSS as well and got them loose!
