ineed help ..... greasable shackles (1 Viewer)
kuwait
how do i grease the shackles ..... Due to lack of space due to the proximity of the fuel tank and has tried more than a grese gun and failed to
Do you have space to replace this standard grease zerk with a zerk that has a 90 degree offset built in? The 90 degree zerk will be a little taller once install which is why I asked about space.
they were installed incorrectly
To install them the other way you would have to drop the fuel tank (this is how my car was done when I got it, PITA, I just cut them off)
No, you remove the spring bushings and install the pin with the bushing loose over it, then push it all into place - it works, and there's lots of space if you do it that way.
~john
install an angled grease fitting 90 or 45 degrees, easy and cost a couple bucks for a pack of them.
~john
Your not just a pretty face, an ideas man too!
