POOCHED!! In my opinion
As for the exhaust valves, I would replace them. Seems like cheap insurance to me.
Is this typical for old valves, or these look particularly rough?
I think it'll be ideal for the lighter work, like tuning up the AFM and similar. Wouldn't expect to be able to rework the ports of an iron head with it, but you knew that!
Speaking of, when you get around to grinding on iron, wear a good respirator. Your lungs & nose will thank you. First set of heads I ever worked on I was 16 and didn't know any better. That was some funky stuff that came outa me.....
Specs for Sealed Power billet replacement, rocker ratio is 1.5:What is stock valve lift with a 2F/3F cam? I've seen ~0.43" for one after-market cam, but never a figure for the stock cam. The witness marks on the valves I pulled seemed to suggest a greater lift, but this could be from some valve float? Or maybe the engine the head was pulled from even had a high-lift cam?
No, the springs and rockers stay in the same relative position. The .050" off the head is easily made up in the adjuster screw.On a somewhat related note, is it typical to cut the length of the push rods an amount equal to the shaving of the head to retain full travel of the springs?
This post reserved for summary, links to relevant threads/sites, etc. Will be updated as things progress.
A full suite of high-resolution photos can be found here: RockDoc_photos - Photobucket - Video and Image Hosting
Some relevant threads:
Jim C's comparison of the 3FE head to the late 2F/3F head
matt.mcinnes' 2F-ETI build thread
Matt's head-focussed thread from the above build
Randy and Mark freshen up a 3FE for the 62
Randy and Mark freshen up the 3FE in Randy's 40
good camshaft thread
another good camshaft thread
Some short threads of mine that led to this:
Best way to clean the head casting?
What parts do I need to collect?
What's it going to do for economy?
Early musings
Just incase anyone is wondering, Canon PowerShot S3-IS, macro and supermacro settings.![]()
It seems the first 4 links are brokeded.Doc - check your Jim C link - it does not work for me...
