How long does it take for the mold to set up before you can pull them??
Doc,Jim: If you happen to have examples of the Chevy 1.50" and 1.84" valves handy, could you post up a couple pics of them? (particularly profile) Curious to see how much meat they have to them for turning a rim-flow profile on the intake, and if they have a flat face to help counter any chamber volume increase that will come with de-masking the intake valve a bit. Couldn't hurt to have fresh bushing and seat surfaces machined too, as you pointed out.
That is way cool. So how about Producing a cast when your done with this project and making your own heads?! It worked for Edelbrock.
The great thing about using the SBC valves is they are available in many different styles. Re-read Vizard's chapter on valve & port shapes, look for info on how the valve & bowl should be shaped, depending on whether flow comes across the back of the valve or down onto the back of the valve. I would call this head a 'down onto valve' style.
It might be educational to make similar molds from a head that is known to work well out of the box. I'm inclined to suggest the GM Vortec SBC head as one such sample.
Had I any Vortec heads they'd be bolted on.Donor head? Donor silicone?![]()
"8" between #1 and #2
"1" or "I" between #3 and #4
"G" between #5 and #6
"61080____8___1____11" above the ports for #5 and #6
Thanks for the link for the valves, cheaper than I would have guessed.
I think the date code is 8 1 11, i.e. 1988 january 11th.
Is the Sili spendy? Source?
Doc, do you know what the block number stamped on the block by the starter was? I am trying to determine the vintage of my 3FE (don't have block # w/ me here at work...)
excellentThat would prove Hilux right. (sorry, I doubt anyone but Crazy8s is going to get that one) That would take this much further than I'm capable of.
