If the pedal isn't hard as a rock, explain how it could be the booster, I just don't see it.
We took vacuum off booster, had hard manual pedal but it faded to no brakes just the same.
It is not about the booster, you are correct, as Beno pointed out it is about the travel distance. Due to the extra distance, if not adjusted, and the resistance of the mechanicals, it will not simply glide until it makes contact. It will "feel" spongy to most people, at least to those of us who aren't experts.
In my case after changing a MC, brakes, all fluids, the brake booster, and bleeding with the two man method, pneumatic bleeding, running a hose from each brake and lpsv to the master cylinder I still had crappy spongy feeling brakes. After replacing the booster I had quite a bit of brake travel and the position of the brake pedal was not too my liking so I climbed back under to adjust. After three complete turns of the adjustment rod I had the best brake sensitivity I have had since I bought it. Nice and firm. No issue with the "travel distance" I have been reading either.
As someone who has to work with personnel who are not electrical experts when troubleshooting electrical issues in electrical distribution systems, it is sometimes difficult to understand what the real issues are, you have to read between the lines. I recently had this when trying to diagnose issues related to power supplies failing at a computer facility. What I am getting at is we all try to describe the problems we are seeing, but if you are not in the business, your descriptions may be misleading. The main culprit for spongy brakes is air somewhere in the system. But when you have ruled that out it must be something else. In my diagnosis of my brake problem I did not understand the ramifications of the push rod not being adjusted, how would I, I am not a professional. I also did not know how it would "feel". A true brake expert probably would have figured this out toot sweet after they also bleed the brakes, or even before if tested.
In the end you pay for experience in one of two ways. You either pay for the professional who has the experience or, you pay for your leaned experience. The later is often times much more expensive...
