Feels more like The Neverending Story
I know right? Sheesh.
Uh... Never said anything was wrong. I am intrigued by the problem though. It seems like these guys have been going after it pretty hard for a while now. Wondering if they have anything new. And definitely curious how it will end... if it does.What's wrong with that?![]()
Working on them right now
Here's a schematic diagram I found in my collection of files that shows the entire FZJ-80 braking system. I don't remember what 'mud thread this originally came from, but the schematic matches the physical fluid circuit layout that was posted several pages back. What's nice about this one is that it shows how the ABS pump fits into the fluid circuit. It's also the first document I remember seeing that calls the solenoids a "3-position solenoid" and not 3 separate solenoids. Previously I had jumped to the conclusion that there were 3 different solenoids in the ABS actuator. And back in post #85 Pin_Head suggests grounding pins 1, 3 and 4 on the 6 position plug in order to activate the all solenoid valves at once. But now I'm thinking this isn't the right way to exercise the ABS actuator. Instead what you need to do is ground those three solenoid connector pins one at a time and also activate the ABS pump for a few seconds during and after when each solenoid circuit is actuated. Doing this will pump brake fluid through all the internal fluid circuits of the ABS.Does anyone have flow diagrams depicting the ABS system?...
Just to be clear, the schematic diagram shows 3 separate fluid circuits for the 3-position solenoid. So you need to activate each circuit (LF, RF, Rear) separately in order to exercise all 3 fluid circuits. Maybe, somehow, you've still got air trapped in one or more of these circuits or the two internal reservoirs that are shown. Obviously I'm just guessing here, but it's a fresh idea to what otherwise seems a vexing problem.
LOL, yea, I was curious too! When you work on brakes so long, then you test them, and the question, "How do they feel" comes up. There is never a good answer, hell, they are different than they were, but better, IDK. I got so used to crappy brakes that I couldn't tell crappy from really crappy.Uh... Never said anything was wrong. I am intrigued by the problem though. It seems like these guys have been going after it pretty hard for a while now. Wondering if they have anything new. And definitely curious how it will end... if it does.
