Greetings from the UK,
My beloved FJ40 is having some starting issues and ignition concern. No spark and havn't figured out if coil (looks OEM and old) toast or something else. However, I have heard how the Petronix electronic igntion swap is simple and reliable and can make drivability a lot easier. What is the current thinking on igntion upgrade (or not)? My FJ40 is largely original except for shocks. But I gather you can 'hide' the Petronix in original distributor and always reverse to point, rotor, cap etc. if one wants later.
Since I will likely need to order any electronic stuff from US, welcome some input. I read the horror thread about swapping a distributor(Maxx) that was too short and blew engine! Is the DUI swap overkill or one that once done and dusted goes and goes?
All the CA smog stuff is mindboggling and wanted to see if this effects the decision making process as well. Might be as simple as replacing coil, clean points, adjust and replace rotor, cap and plugs and cables (they are a bit old as well).
Thanks as always,
Thanks as always,
