Hi mud family I’m doing the timing belt and I noticed the radiator has this pink stuff on the side and do u think should I change it or can I still reusable it? and If I need to replace what brand u guys recommended?
When I drained it The coolant was pink can I switch it to red becoz I already have 2 gallons of red coolants at homeSilly question, you must replace! Cant remember the brand of preference, I am sure somebody will chime in with it. Easy job, don't forget to use Toyota Long Life Red Coolant.
Denso is the oem brand. I got mine on amazon. Replace the water pump too if u don’t know the condition of it. There’s an Aisin water pump and timing belt kit.
I put the part numbers on my build thread in my signature.
@chiz45 good list. Add replace the radiator cap.
On the fan clutch, I didn’t replace. It’s not a common failure point as far as I know
