Chef's orion shifting woes
Briefly, Steve Cramer, aka Posuer, is pretty smart. My Orion mostly went together fine. AA installed the idler cluster, which I had to remove to get the low range gear in. Thanks AA. Rest of the job went just like any other one piece transfer rebuild. Orion ran great for about two weeks, then started popping out of 2hi once and a while. I ruled out shift linkage, and spent a bunch of time talking to Cramer. Some thoughts and my possible solution for my cae are below. I believe the case of it all in my case was the case was machined too deep where the shift fork locator tab goes...read on:
Steve, thanks for taking time to help me thru all that. There was about .070 for the shift collar to move back towards the low speed gear with it engaged in the low speed detent. In the high range position, it was missing going all the way into detent by ~ .040, and the shift collar was htting the high range gear. I shimmed the shift rail locator tab back .050, leaving about .010 of free playfor the collar to float in both high engaged, and low engaged. Seems to be ok now in my short test drive. I plan to commute with 'er as much as possible before Ramble, maybe get out on some trails this coming weekend. It was alwys fine in low, but popped out of 2hi several times on the street. It did not appear to be a shift linkage problem, but rather a case machining error leading to shift rail detent misalignment. Feel free to post this in whichever thread you think it ought to go in. I hope you never hear from me on this subject again except perhaps to say "it's all still fine"
Thanks, Alan
