treerootCO
Where are my keys?!
- Thread starter
- #101
I broke my junk so others can learn
I'll post as soon as I figure out the spacer...
woody said:What???
#32 is a spacer for t-case output shaft....completely unrelated to the t-case input gear or idler cluster....installs next to the toothed gear for the speedo drive....
peesalot said:fawk , fawk , fawkin spacer , what who and where the hell. Not in my 420 adapter instructions , please advise as to the thickness of this , I found 1 that is about 1/8 inch and was in the box from the tranny rebuild and I am suspicious that this is it ???????
mustardfj40 said:I thought it's part #11 in the SOR pic???
/td
Poser said:EXACTLY Brian...
That IS the spacer that I have in stock, and used on all 420 and 465 plate style conversions, since 1993.
treerootCO said:I thought it was spring toward tranny.
treerootCO said:
Hey Steve....can you elaborate on the safety wire pic? The angle doesn't show what the wire does above and below the bolt in the pic. My guess is that there is some kind of tab welded to the washer but it is hard to tell.
at least you're not working on a jeep againPoser said:-Steve......back in the shop.....working on a 4runner....???????![]()
Pin_Head said:Looks more like rebar wire than safety wire, but I bet it works.![]()
