We the people of this forum demand updates
Ok, got my PWR 4X10 water/air intercooler, bought a rad/fan and pump from siliconeintakes.com, just checked my compression and I have 600-620 in each cylinder. So, the install will begin next week, looks pretty easy, all I have to do is fab up a bend from the turbo to the intercooler. Found a place behind the cab for the rad and fan.
Pics coming soon.
Louis
I didnt use a bracket - it is so light and my piping was rigid so there was no problem - this new one will need to be mounted though![]()
Boost comp installed, engine installed, test drive is 100 percent. 4Terrain clutch is very smooth, no more gear box clatter after the rebuild, tranny is super tight. I use MT90 Redline tranny fluid, and redline 75-90 transfer synthetic, everything shifts great, I replaced the synchros and everything shifts like a new tight box - which we all like.
I can add tons of fuel and am boosting 10 pounds (with limiter) and I get no smoke at all, the smaller a/r give boost right off idle and it is awesome -will be much better for wheeling.
Truck goes in for new paint in the next week or so.
Louis,
I'm looking at getting an OEM boost compensator for my HZ now from Dave at Japan 4x4. If you are not running the OEM compensator, which one are you running? Did you run your HZ turbo'd but without the boost compensator? If so how did the engine run? Also it sounds like you are running a boost controller/limiter? Which one? Dude you know me, I'm just here riding in your shadow and stealing your ideas.
Thanks,
John
LOL, John, dont worry about it! The boost comp I talked to dave about already, iirc he said to just get it from all american imports as it was probably cheaper than what he could get it for. The boost comp is a toyota part - but I couldnt get a part number off it. I think with shipping it was about 250 bucks - then I had it installed at a shop.
I just use one of those little knob boost controller things off ebay - was about 40 bucks, work well though and has been under water several times. Tricky to get the tubes right the first time though - get one and I'll run you through it.
I did have the turbo on without the boost comp for 2-3 years, I had my pump set up pretty well and didnt smoke very much at all as I never really ran excessive fuel through it. I owuld get some smoking down low in the rpms until it revved up but now with it on I have no smoke anywhere in the rpm band - I'm digging it.
One thing I have found is that these two engines I just set the valve shims on were out of sdjustment by quite a bit, the engine from japan is so carboned up it is crazy, I have to take it for a couple hundred km run to get it all warmed up and burnt off. But, when i set the valve shims the numbers were way off - I suspect carbon was messing up the numbers. One shim I put in was very thick and went against my better judgement - anyway the first time I stated the engine I got the hot intake manifold from the intake valve being partially open. So - the lesson here is that if your tolerances are out .25mm then you are going to have excessive heat and other issues - so set your valve shims if you already haven't.
