HZJ75 (5 Viewers)
Windscreen frame took down for new replacement.
New frame on the way and lead time due to the recent earthquake.:)
Arrival of the brand new windscreen frame.
Frustrated that this frame is without any gum on the edge or joint.:mad::(
Its normally done by the body shop. Even new doors don't have it
After market gum will shrink after a couple of time unlike the factory gum willstand quite long.
I wonder what material is the factory gum?
All brand new landcruiser from Toyota will have gum on the joint and underneath mudguards but not on the new parts.:(
funny.:crybaby:
Arrival of fender seal(RH only , LH is in search), tail shaft, rear windscreen rubber pad.:);)
Grasp hold of toyota genuine front HZJ79 chrome turn signal lamps.
Replacing the non genuine lamps.:)
Hope he is fine. Did the chasis bend during the hit?
Chassis took a big hit check the door is back also the beaver panel has blown out chassis will need work. If you want a good chassis look at OZ. Plenty of our late computer cruisers are written off for wet floor carpets believe it or not.
Well, he told me the chassis is all right.
what I had examined, the chassis was bent.
Will have to wait till the cab to crane out for further inspection.
The drag link was the culprit for this accident.
