HZJ75 (1 Viewer)
There are actually 2 routes to Tawau by land. One is gravel and one is tar road. Both takes about 7-8 hours drive depend on your speed.;)
or u can take a plane which is 45 minutes long
This JRJ is an accessory shop at KK adjacent to kolombong highway.
Furthermore, this is an import model come with the factory rear bumper, nor do they import the bumper and sells it to the public.:D
This cruiser should belong to the government and only they are allowed to import.:mad:
ya the side window is different, it has air vent. do u fit in rubber at ur tailgate like that to avoid scratch too?
Mercedes Benz and Nissan Diesel are the famous of all among Sabahan. Mercedes Benz is the king of the jungle after landcruiser:D
What???? 7-8hours from kk to tawau Omg....In Our place we use Nissan Diesel and fuso as engine and the axle we use MAN ...Wong,I'm jealous your 75 with 1hd heart
what's wrong with 1hz if compared to nissan and fuso? and what is MAN axle?
UD truck is no longer cheap stuffs. A front cut easily cost you a Landcruiser HZJ75. :D:D Fuso new truck is getting famous now due to the rising cost of a rebuilt truck.
What Man axle are you using? Large 13t or small 10t??
By the way, you don't have to jealous of my 75. You can serve your cruiser with 1HD as well. We definitely need a 75 with gut to carry spare parts or tires for our trucks.:crybaby:
Nothing wrong with 1HZ and is a bulletproof engine.
Man axle is equivalence to Mercedes Benz axle .:cool:
The UD diesel is not cheap now a RH10 engine already cost 50k but all prefer UD engine than Fuso engine....I really don't 13t or 10t they using sometimes I curious the truck using Two low gear transfer box on the truck...better we call it three nation truck From Malaysia+Japan+German Truck...hahaha :)....Wong,is 1hd engine expensive?
Lee, the 1hz engine is unbreakable...yesterday I went to a goverment office I saw a condemn 80sseries the 1hz is already jam but the engine still look clean no leaking at all ...if can get 1hd more better can't get bully by Vigo on the road....hahaha
cheong i feel the pain of being overtaken by vigo too :frown: I think this is due to small rear diff on vigo makes it spin faster. here is a link to a halfcut shop that sell 1hd http://www.kinaway.com.my/6.html. the boss quote me RM12k for 12 valve, RM13k for 24 valve.
Well, that's too bad. I really thought I had read/heard that these were interchangeable. I know I replaced the front rotors on my 70 and now I'm wondering what I actually bought for that, because they went right on with no issues. Eventually, I will need to do the rear as well and was hoping the 80 parts would pan out.
Well, I tried to put the 80 series rotors on the 75 series axle and even with the 80 series hub, it still won't work. Two problems that I can see that stems from the difference in the rotors. The outer and the inner (PB drum) diameters are larger for the 80 series. For the overall diameter being larger, the parking brake backing plate/dust shield it smaller, so you cannot drop the 80 series rotor in without either bending or cutting off the lip of the backing plate. Second, the center hub/drum area is also a larger diameter, which may be enough that the parking brake might not grab the rotor.
I think you'd have to swap over the backing plate and maybe parking brake bits off an 80 series axle to fit the 80 series rotors on. Too much work just to fit an 80 series rotor when you use the same caliper:meh:
Fun experiment, too bad it didn't pan out:grinpimp:
The 12v is more robust than the 24v?
Will a large front disc rotor of 80 series went right on in 70 series with no issues?:confused:
My research tells me is not feasible.:hhmm:
You can't overtake a vigo even though with 1HD on 75.:mad::mad:1HD isn't an omnipotence engine, you have to look at the diff ratio as well, all takes into account. 1HD is full of gut and unbreakable engine to what I see.
(RM13k for 24 valve):eek::eek:
Wrong quote for 1HDFT, you can't get it at this price. RM18K sounds better.
That's the reason why I went for this.:D
One of my friend swapped a 1HDFT into his 79. Result was dismantled twice for his engine. :hillbilly:
sorry for the wrong info
wong can u ask ur friend where he get his rims
