HZJ75
What rim do you want to ask?:hhmm: Should be at KK.:D
I wish to ask for alloy rim, not 105 steel rim or sunraysia. I need to know the exact place in kk and contact number if available. thanks ;)
That's why i need ur friend help for contact =D
it wrote PCD139.7 X 6 not PCD150X5, it's the same design as urs!
Is a 5 stub rim for 100 series. :mad:
Writing mistake by the seller, title stated as "Ninja King":D
Why not give a buzz to the seller?
What is your budget?:confused: Will try to ask my friend to help you.
Thanks! below RM4800 for 4
Fast and Furious red HZJ75 + turbo
ARB bullbar with side railing + Safari snorkel.;)
1HZ + turbo intercooler.:p
Do you know who is the owner? I had seen it a few times near Apas Mile 3 Industrial area.
Is that waste gate plumbed back into the exhaust Wong or just out to the open screamer pipe style
Yup! know the owner.:D
hot looking little unit.
About waiting on 4 studs to come in the mail for my turbo and exhaust install!!!
What is the 4 studs for? :hhmm:
Waiting to see your mod;)
Yes! Exactly. And down to the end is an air horn tube and is super extra loud screamer. :clap:
Does he use back the original fuel pump? If he place the intercooler in front, where does the aircond goes? :eek:
Fuel pump with added compensator, looks similar to 1HDT.
That bar work is really really good!
Lol..just realised ARB!!
ARB bar work is really good, so as the PRICE!:D
4 studs and nuts are for the turbine flange to connect to the dump pipe.
I just can't be that patient waiting for the 4 studs and nuts to connect.:o Why do you need to send from somewhere??:confused::hhmm:
Where is the air-cond radiator since the intercooler replaced its place?
Patience is a virtue....:D
You have drop in 2 cents into my pocket!
Doing all the mod to my cruiser really test my patience and endurance.
And I conquered.:cheers:
Both the intercooler and condenser can be mounted in front of the radiator.
The aftermarket air-con condenser isn't thick enough that no where to place itself.;)
