What is the different between the spindle??
Not really having the idea of swapping a 80 series axle, want the stock axle.![]()
Wong, do u use ur 75 to carry heavy load?
80 series axle is comfortable =D
How much is a hzj 75 cost now?? Last year I brought one hzj75 94 on Rm32k
My 75 can carry a Bulldozer winch and still can speed up to 120km/ph....Tough truck ...I like it so much
Hard to tell, I haven't had a 40/60 and 80 series hub or spindle side by side in a while. If it is shorter, longer, different circumference, you wonlt be able to bolt the 80 hub to it. Can you bolt an 80 spindle into a 70 series knuckle? And if you can bolt/attach what you want, I don't know if the 80's calipers will bolt up to the knuckle or if the rotor would line up with the caliper.
circumference should be the same as cruiser shared the same bearing between 70 and 80 series.
I think the major issue lies heavily on the length of the spindle.
I'll try to check this out.![]()
it is more expensive in sabah. hj75 RM30k-40k hzj75 RM40k-65. Wong's hzj75 worth RM80k but i bet he won't sell at that price![]()
75 is meant for carry heavy load. Of course I use it to carry my truck spare parts and 22.5 tires.
I don't really like the idea of welding and cutting on my chassis.
All depends on the condition of the cruiser. 91 model could cost more than a 99 model if the condition is super decent.
Show us your 75.![]()
Another question, if you could bolt the 80 series hubs, calipers, rotor and everything lines up, will the 75 series master cylinder have enough ooomph to get the max benifit of the 80 series calipers? Kind of the same issue of people that swap the V6 4Runner calipers onto 40 series using the stock MC.
cheong!
Did you fit that factory snorkel?
I can't see your no plate.
BTW, what happened to your tail lamp?
Replica snorkel not OEM
Poor camera on my phone,my number plate is WDN 4086..hahaha
When brought this 75 the tail lamp is already gone missing ,I keep search the OEM tail lamp but I can't get ...sad ..so have to modify a lorry lamp DV57 LED to fit the 75.......now my place got another one hzj75,the owner brought from Sabah when last time he work at Sabah the plat number is ST6636C with OEM PTO ,,,
Mr Wong,planning to change the front leaf springs is so bumpy,can give me some advice?
We have the tail lamp selling here. Used or new is available.
Or you can grasp one at the used part shop around KL, mainly Dyna truck from Japan, exactly the same shape and pattern.
ST6636C plate is from Sabah Tawau, that's the place where I'm from. Should be the year 91 or 92 if not mistaken.
You can consider coil spring if you want super comfort.
Personal view, nothing is comfort with leaf spring. If you insist on leaf spring, I would recommend Aussie aftermarket spring. OEM, dobinson............
it's nice to see another 75 from Malaysia![]()
