If you have a flaky water temp switch then this could cause the AC to cut out when the temperature is hot. (Note that there are 3 water temp switches in the engine block.) You may also want to test that thermistor and the engine coolant temp relay. -
It's not cutting out when the truck is hot, it just cuts out when it's hot outside, well, it did for a period of time, speratically, now it's perminate. Besides, it's not that the a/c is cutting out, it's that the whole control is dead. If the control was functioning, and fan running, at least I'd have defrost in the morning rain rathter than driving 1/2 blind.
I will also offer another word of advice if it is not too late. Don't be an A-hole to the GM and the tech that tried to fix the problem. Call them back and ask nicely if you can speak to the tech that did the trouble-shooting. Wouldn't you like to know if they have already put in another A/C Amplifier and eliminated that as the problem? Maybe they have tested some other things that would help you in getting this working and a tech isn't likely to give you much assistance if you are belligerent.
Just a suggestion from old Beo so take it for what it is worth.... It probably isn't very hot in Oklahoma in July and August so maybe getting this fixed isn't a big deal.
-B-
I spoke with the tech. He was no help. Wasn't cause I was a 'a-hole' about it, he was just vague as heck. Can't say I'd trust anything he said anyway, they couldn't even plug all the switches back in before returing it to me, it's not like I'm going to trust that he tested anything correctly.
Had some time to look at it again. Did a nice little video clip of opening up the dash and finding all the parts that weren't plugged in, and pictures of the ashtray light stuck inbetween the panels keeping them from fitting. They should make my case for why they owe me for fixing what they screwed up. If not, it's gonna look really nice on utube!
I pulled the AC amplifier out PN88650-60212. Opened up the case to look at the PCB. It's had water in the case. The connections are all corroded and such - have photos, will attach when I get a chance to load from the camera. Went to get one from a local junkyard, and it was full of water. Don't know where the water is coming from in my truck, the yard one had the windows out. It's not designed to be very water tollerate that's for sure. The top is open, and the bottom is closed, so there is really no place for it to escape if it does get condensation or what not in it. Ordering another used one today. So hopefully will be resolved by the weekend????
Oh, and yes it's freak'n hot in OK, only salvation is I'm not driving the truck at all, I'm riding my cycle, cause who can afford to drive a 10mpg truck at $4.00 a gallon? Would be nice to have it for rainy days, and for it's main purpose - 4wheel'n though.
