For the past 2-3 months, there is a humming/low frequency sound, that appears to be coming from the left front. It is louder when accelerating, and does away as the trans shifts gears, and then reoccurs as you accelerate under increased RPM's. At cruising speed it is not there. However as you accelerate, you do hear it. Seems tied to shifting and engine RPM. Seems more pronounced on uphills?
Trans was serviced 5000 miles ago, and shifts very smoothly, both upshifts and downshifts. No slippage at all. Noise has not gotten any louder. No vibration in th floorboard, and normal slight vibration in the shifter, same as when the truck was new.
Seems to occur under load while accelerating. No noise at cruising speed in OD.
Any thoughts? Thanks
