Why did you replace the plug as well as the washer? Did the plug damage while removing? Thx, Clay
i think this is the part number for the hex bolt deal we're all taking about now... I'm getting one for my next oil change as well. Thanks guys, Clay
How much torque does it take to loosen and re-tighten? I tried removing mine and couldn't get it to budge. I got concerned I would break something and stopped!
You wont break nothing, if you can bench press 250lbs you should be good to go!![]()
So I was back under my car to do a coolant flush and took a look at my oil pump gasket (area) and crank seal and verify my leaks had stopped.
Everything looked dry except for this hex nut near the oil pump cover...anyone know what this is and if it is an easy fix??
This are the part numbers you will need to get it done!A VERY EASY FIX! PLUG STRAIGHT SCREW part number 90341-27006 and GASKET # 90430-27005 to be oil leak FREE, mine had a small leak and I had to order these part numbers to complete my JOB.
Is torque important on this??? Or just snug it up?? (Talking about the hex screw..not oil pump cover)
Also, would you use any blue loctight?
If anyone else does this it would be great if you could document the leak with photos before and after.
On mine I thought it was the oil pump or the distributor, however I lucked out and it was just the hex nut!I'm going to clean the area as you've stated and watch it. My feeling is the seal on the power steering pump is my problem. Eventually I'll have it all replaced (seals and o-rings, etc) and I'll be completely leak free!
Lastly, the deep 14mm socket on the flywheel bolt to hold the crank to get 305 ft/lbs of torque. I don't see a problem with this method, but I did not like that the socket could slide off the bolt and I thought it needed support. Using scrap wood and a shim, I felt better that the socket would not move, and it didn't.
The photo helped me understand the scrap wood trick, but I like it. I was thinking that the socket would come off that bolt too, but it held up for me. That thing wasn't going anywhere with your extra block tho… nice work!
I read in previous posts of sockets splitting, etc. If the socket stays square on the bolt, that possibility would be minimized. It's not pretty, but it did the job, piece of mind for sure. In a perfect world I would fab a tool to hold the balancer as Toyota intended.
