Alright guys, I got the video footage all edited and published on my Youtube channel. See the video on how to do these oil leak repairs here: http://youtu.be/4IT5T647xII
I really leveraged the thread here and most of the "tricks" folks have come up with here, I tested and used in the video. So hats off to you guys and I hope the video helps those folks who are visual learners! haha
Take care, Clay
Very nice video,, thanks for taking the time out ,,,, much appreciated.
CRUISER TIME
Just wanted to add my .02 on this job. The starter bump with a 3/4 breaker bar and socket worked like a charm as did using a 14 mm impact socket on the flywheel to tighten the crank bolt. That crank bolt is huge at 31 mm in diameter (shown next to a 8 mm bolt)!
I removed most of the oil pump cover screws with a Milwaukee M12 impact driver. It worked really well. One screw was being stubborn and I hammered in a PH3 bit and used an 18" long breaker bar to back it out. There is a lot of room between the oil pump cover and radiator to swing a hammer. The breaker bar worked well and I wouldn't buy a compact impact driver just for this job, but it is a great tool to have.
My cover needed a little lapping. I used 400, 1000 and 1500 grit paper. I should have spent more time on 400 ( or even 320) before moving up in grit. I used new torx drive flat head screws from 1fzfephh.com and a Wiha torque screwdriver to torque each screw to 50 inch pounds (max setting on driver). I don't think I could have turned the driver much more, but I would have run them to 60 or 70 inch pounds if I could. I also added a little blue loctite to each screw for extra insurance.
My largest torque wrench only goes to 250 ft lbs. so I made up a 14 inch extension at a friends shop. I still had to set the wrench to 192 ft lbs. I should have made an 18 inch or longer extension, but it still worked out fine.
Oh yeah, I'll be doing a steering pump and associated hoses soon. Mine (80S) is starting to whine and leaks pretty bad. All the front oil leak fixes are still nice and dry!![]()
So I was back under my car to do a coolant flush and took a look at my oil pump gasket (area) and crank seal and verify my leaks had stopped.
Everything looked dry except for this hex nut near the oil pump cover...anyone know what this is and if it is an easy fix??
I would also add the PLUG STRAIGHT SCREW part number 90341-27006 and GASKET # 90430-27005 to be oil leak FREE, my had a small leak and I had to order these part numbers to colplete my JOB.
i think this is the part number for the hex bolt deal we're all taking about now... I'm getting one for my next oil change as well. Thanks guys, Clay
