I've seen mine advance as high as 38* on Scangauge, at least while I was paying attention. What I don't understand is how it doesn't ping at 38*. I guess AFR is just right?
That makes a lot sense scott!
Just curious if you happen to know the timing difference between 91 and 87 fuel on any given engine.
For example if you are operating at high rpms and you are seeing 38* on your scan gauge and you have 3* timing you are firing the spark plug 41* of the crank before the piston is at top dead center.
No I don't agree with that. The scan gauge has no way of knowing what you set the base timing to.
I believe that people are confused that when they set their base timing and at 3* and the computer shows 3* that they are running a total timing of 6* degrees but just because the numbers are the same does not mean that they mean the same thing.
Just to clear this up:But it appears that the timing being displayed by the scangauge is the total numbers of degrees advance, not just what the ECU is adding to the base setting. (See previous posts in this thread.) So if you are seeing 38* on your scan gauge and you have 3* base timing, then the ECU is adding 35* of advance. Of course this doesn't change the other points you made in your post, rather just what it is that OBD II is reporting.
I didn't move the TPS sensor at all. There's some loctight on the set screw so I know the position hasn't moved.Did you mess with your tps sensor at all is it in its exact position and plunged all way in, distributor I believe points at number one spark plug when out back in
Marking paintLocktite or marking paint?
Sooo, how do you adjust the timing on an FJ80? I have a '92, I live in Colorado, and would love to take this thing up to the mountains without feeling like I'm going to get smashed by a Semithe FJ 80 was the 91 and 92 and had the older 4 liter engine.
Timing for the FZJ 80 is simple.
- Clean off the timing marks (they are on the engine at about the 12 o clock position above the crank pulley)
- Let the engine warm up
- attach the timing light to the battery and put the probe on the plug wire for cyl 1 (cylinder at the front of the engine)
- aim the light at the crank pulley and see where the mark hits
- loosen the adjustment bolt on the distributor (I think its on the bottom side if I remember right)
- rotate the distributor until you are at roughly 5-7 degrees advanced
- Tighten up the distributor adjusting bolt
- take off timing light
- drive
The timing mark is on the front of the flywheel, visible thru a small window on the front of the bell housing. Below and behind the dizzy.Sooo, how do you adjust the timing on an FJ80? I have a '92, I live in Colorado, and would love to take this thing up to the mountains without feeling like I'm going to get smashed by a Semi![]()
