I've used POR for years,muscle car resto, jeeps, trailers, frames etc.I've never used the precoated grey-then black, especially if your doing 2 coats, but I do use the cleaner & prep. If you don't really prep everything Good, it doesn't work that well. I've also not used the Top Coat much, that's mainly for UV protection, and even then, I took a trailer down to bare metal, prepped etc, & topcoat, held up good, but still faded ! Also if you haven't used it much, keep some WD-40 around, to get the POR off your skin ! Only thing that removes it ( if you do it quickly), else you wear it for a couple of weeks. Buy smaller containers, it only stores if you seal it really well, I usally turn mine upside down, once open to stop air from getting in the can
