FAQFAQ SearchSearch MemberlistMemberlist RegisterRegister
ProfileProfile Log in to check your private messagesLog in to check your private messages Log inLog in
1HZ turbo suitabilty
View next topic
View previous topic
Post new topic Reply to topic Outer Limits 4x4 Board Forum Index » Toyota
Author Message
GQ4.8coilcab
PostPosted: Sun Feb 18, 2007 4:36 pm Reply with quote Back to top
hey guys, Ive used the bible and cant find what i want. What ball bearing garret turbo would be best suited. I am looking at a GT25 internal wastegated. Any body used these. What about the disco potato GT28rs. Does anyone know how if it is possible to put the 12mm 12HDT plunger in the injector pump. Or just a boost compensator on the standard pump is enough. I want to run about 16psi. Is this too high. Is the motor not strong enough. Any help would be great?
Thanks Julian
Edit: forgot to add I will be running a front mount intercooler or barrel cooler if that makes a difference.
View user's profile Send private message Send e-mail
GQ4.8coilcab
PostPosted: Mon Feb 19, 2007 4:43 pm Reply with quote Back to top
nobody?
Dzltec
PostPosted: Mon Feb 19, 2007 7:30 pm Reply with quote Back to top
First of all you need to set a power figure you want to acheive. The mods will then be determined by that. A standard 1hz pump is only good for 90-100kw.
A boost comp needs to be fitted to keep exhaust emmissions clean under all conditions. Once you know your power requirements then comes matching a turbo to suit, then fueling requirements.
Yes a 12mm head and rotor can be fitted, but its not just a bolt in and away you go fitup.
I dont kow of any high powered 1hz's. You may have to be a guinea pig to find out.
Hope this helps
_________________
www.diesel-tec.com.au
Home of the twin turbo 80 series,
150rwkw+ patrols
View user's profile Send private message Visit poster's website
Dzltec
PostPosted: Mon Feb 19, 2007 7:48 pm Reply with quote Back to top
Hope this helps
_________________
150rwkw+ patrols
dumbdunce
PostPosted: Mon Feb 19, 2007 7:49 pm Reply with quote Back to top
speak to west end diesel, they have built some fairly powerful, internally standard 1HZ's. Phill (slowhilux) off this board has a turbo'd, intercooled, 3" exhaust, boost compensated 1HZ running 14(?)psi, internally standard, and it goes hard. be prepared for sticker shock though, it is an expensive shop.
the limits of the pump in standard trim depend on how much smoke you are prepared to put up with (and to some extent, how religiously you change your oil). I have turbo'd 1HZ's with no boost compensation, running 9psi with no intercooler, EGT's around 520C MAX, and almost no visible smoke off boost, sure you can get more go out of it by turning up the fuel but it doesn't need it - there is a reasonable balance to be struck. with the right turbo and exhaust, boost is available right off idle so smoke is minimal even without boost compensation. I have used the ceramic turbine, ball bearing nissan-imitation-garrett from 300ZX on several 1HZ's with good success (ask DX80, or surfection/ferog).
as Dzltec says, find a turbo that makes the sort of power you intend to achieve, or about 10 - 15% more (indirect injection robs a lot from the boost) and work from there. If you are building custom, the good news is you can build a VERY short adaptor from the standard manifold - about 35mm long from memory, just long enough to have the manifold studs clear the turbo flange. you could probably go shorter if you trim a bit off the manifold studs. that's enough free hints!
cheers
DD
_________________
mmaaxx wrote:
... its people like you who stop legitimate people in the know exposing any information...
GQ4.8coilcab
PostPosted: Mon Feb 19, 2007 8:44 pm Reply with quote Back to top
thanks for the info. I want reliability but I want to keep up to the 1HD. Is this possible. I am thinking gas aswell. Everyone has boosted TD42's (35psi and more) but i cant seem to find any info on the 1HZ. I might be the guinea pig if i pass the hat round and you put in for the new motor Laughing
ads80
PostPosted: Mon Feb 19, 2007 9:46 pm Reply with quote Back to top
i am running 1hz with 25-30 psi no probs so far motor has balanced turbo pistons,crank and rods all seems to work good just hope it lasts Laughing
_________________
80 series with chrome wheelnuts !!
Chucky
PostPosted: Tue Feb 20, 2007 7:11 am Reply with quote Back to top
Have you dyno'd this engine?
If so what sort of power are we talking about.
I run 16psi in my 1hz and it goes hard, would love to heard how one goes with 30psi
_________________
Team Dyslexic
RFDS Fun-Raiser.
tuff 75
PostPosted: Tue Feb 20, 2007 7:36 am Reply with quote Back to top
i had a 1hz in my old ute with a dts top mount ic, denco turbo 13psi compensator 3 in exaust and made 152 rwhp with 35s ad 1200 lbs or torque bit smoky down low but it hammerd for a 1hz... The boys at chapmans set it up for me... If u go 2 cruza park u will know who they are.. ( that was the pump maxed out)
_________________
79 series rv cruiser 4 in lift, 305 micky Ts, turbo, chip, 3in exaust ,air bags warn xp winch.
View user's profile Send private message MSN Messenger
ads80
PostPosted: Tue Feb 20, 2007 3:17 pm Reply with quote Back to top
depends on the dyno, they all seem to vary??? but is around 170+ rwkw and massive amounts of torque . it only ever gets to 30psi at around 5000rpm makes around 23ish no probs by around 3000rpm then builds slower from there depending on how loaded it is.
_________________
GQ4.8coilcab
PostPosted: Tue Feb 20, 2007 3:54 pm Reply with quote Back to top
was this a reliable set up. Did it over heat with that much boost. Sounds good you made 152 at 13psi Laughing
slowhilux
PostPosted: Tue Feb 20, 2007 7:39 pm Reply with quote Back to top
I got DTS kit on mine, 3" mandrell ex, compensator, and PWR front mount i/c, at 10-11psi it makes 105rwkw, with 315/75 tires, max egt as it is now it just touches on 500deg. Before all this happened the atmo 1hzzzz made a mighty 46rwkw Shocked
Oh, Brian allready explained all that Laughing
_________________
Phill
TSR - Team s***-tin Racing
Dzltec
PostPosted: Tue Feb 20, 2007 8:00 pm Reply with quote Back to top
ADS 80 care to post a dyno sheet of your vehicle, I have never heard or seen one so high, sounds like you have a monster turbo on it .
_________________
150rwkw+ patrols
ads80
PostPosted: Tue Feb 20, 2007 8:22 pm Reply with quote Back to top
dont actually have a sheet, perhaps you can give me one if i make it to your dyno day, if the car still drives arter rnd1 engel series Laughing will do my best to make it, by the sounds of your comment i just might win a prize Laughing
_________________
balzackracing
PostPosted: Tue Feb 20, 2007 8:31 pm Reply with quote Back to top
run 18 pound in mine, break piston ring lands using acl pistons. can't fit 1hdt pistons in a 1hz with out changing to 1hdt rods, different gudgon size's.
_________________
hzj75, 3in spring,2in cab,2in shackles, fourbys 15x10 beadlocks, 36x12.5x15 simex ET2,
tube tray,turboed 1hz.
GQ4.8coilcab
PostPosted: Tue Feb 20, 2007 9:18 pm Reply with quote Back to top
that did run across my mind and the answer is no
tuff 75
PostPosted: Tue Feb 20, 2007 9:56 pm Reply with quote Back to top
yea mate with the 152 rwhp at 13 psi it was reliable i did 40 000 klms with it like that and did oil changes every 4 thousand ks just 2 be on the safe side had a phyro and boost guage egt i never let it get over 500 but u could get it to 400 quick but hard 2 get over 500..... it was a nice amount of power with out going over board.. put it this way 1 mate had a falcon and the other a comodore and i was quicker than them untill bout 95klmhr
_________________
tuff 75
PostPosted: Tue Feb 20, 2007 10:01 pm Reply with quote Back to top
here is a dyno sheet for anyone who cares
_________________
tuff 75
PostPosted: Tue Feb 20, 2007 10:04 pm Reply with quote Back to top
and not once over heated as i allways made sure all of the cooling system was spot on
_________________
GQ4.8coilcab
PostPosted: Wed Feb 21, 2007 5:30 pm Reply with quote Back to top
that sounds good, you had to be have happy with that power output. Does anyone know what turbo denco use?
tuff 75
PostPosted: Wed Feb 21, 2007 5:37 pm Reply with quote Back to top
the one i had was a schwitzer turbo bud
_________________
Dzltec
PostPosted: Wed Feb 21, 2007 7:21 pm Reply with quote Back to top
Ads 80, bring it on down, even if you cant make it for the day drop by and we will do one any way. I am very curious to see it.
_________________
150rwkw+ patrols
ads80
PostPosted: Wed Feb 21, 2007 10:24 pm Reply with quote Back to top
wont b till after rnd 1 anyway very busy till then the car will b at the swap meet coming up at yarra glen if ure keen 4 a look Laughing
_________________
Dzltec
PostPosted: Thu Feb 22, 2007 6:35 pm Reply with quote Back to top
Yeh I am whens the swap meet?
Thanks Andy
_________________
150rwkw+ patrols
ads80
PostPosted: Thu Feb 22, 2007 8:54 pm Reply with quote Back to top
swap meet + show n shine sun 4th march yarra glen showgrounds
_________________
Chucky
PostPosted: Thu Feb 22, 2007 10:55 pm Reply with quote Back to top
This is same that I run, except I have a top mounted I/C at 16psi on 33's.
I haven't dyno'd it yet, will one day.
ETG never goes over 500. And has run on this set up for nearly 4 years.
Never had a problem with teh engine except for a water pump and collasped battery.
Blows bugger all smoke and goes hard.
I love it.
_________________
Team Dyslexic
RFDS Fun-Raiser.
dumbdunce
PostPosted: Fri Feb 23, 2007 6:13 am Reply with quote Back to top
still only 11psi? come on, let's BOOST it!!
_________________
slowhilux
PostPosted: Fri Feb 23, 2007 9:35 am Reply with quote Back to top
Would like to shove another 3-4psi in it, but she "breaths" a little heavy. Not sure if it has somthing to do with craps baffles in the rocker cover or not. Doesnt use any oil either. Anyone pulled the cover off and made new baffles?
_________________
Phill
dumbdunce
PostPosted: Fri Feb 23, 2007 10:45 am Reply with quote Back to top
too much blowby? maybe a leakdown test before you boost up. if there's just too much oil spray, a catch can will clean it up. There's always some oil there. an engine "using no oil" just means it is burning its oil at the same rate that it's adding contaminants - water/CO/HC/Fuel from blowby etc.
boost it hard, it's only a motor, if it holes a piston you can rebuild it with turbo pistons and then boost it harder!
_________________
slowhilux
PostPosted: Fri Feb 23, 2007 12:39 pm Reply with quote Back to top
Have a catch can, it mists up quite a bit with a filter on it, but mow i have it returning into the intake, with the drain Tee-d into the turbo drain. I mite fill the can with steel wool, to slow down the rate the oily mist enters back into the comp. housing (and cooler/pipes). I know its only a motor, problem is if it s*** itself, i would find it real hard to find the funds to rebuild it. Damn houses, always slow down the spend rate on toys cussing
_________________
Phill
Display posts from previous:
