CharlieS
GOLD Star
Help please.
How do I remove top bolt on bottom end of EGR pipe?
I was up until past 2am messing around trying to get this and am stumped. I just need to get enough leverage to crack it loose.
I got the bottom bolt out with some long extensions from the wheel well with the tire out. I just needed to crack it loose, and was able to take it out easily after that.
The valve cover gasket and upper intake plenum are off, so I have ok access, but not awesome access. I can't see that bolt because of where it sits with the lower plenum blocking it. As far as I can tell, I can't get to it from the top without removing the lower plenum.
The PHH is out (and I thought that was going to be the hardest part - it was a pain, but not compared to this...) so I don't have that in the way.
The opening available in the wheel well makes it very hard to get good leverage with a short gear wrench, flex head gear wrench or a ratchet. I can get them on it, but don't have any way to generate enough torque (you should see the scrapes and bruises on my forearms).
I'm starting to think if my main options (other than take the engine out
) are:
In my despair I even considered drilling a bolt access hole in the inner fender, but decided to go to bed and sleep on it before engaging the power tools.
I know I'm nowhere near the first person to tackle this. Would one of you that has experience here share what you did? Access from top or bottom? What did you have to remove to get to it? What combination of tools finally worked?
FSM is super helpful:
...if the engine is removed and you can hit it straight on. Not so easy with a fender in the way...
1) remove the lower intake plenum and do it from above, or
2) remove the starter, transmission dipstick and anything else limiting access from below
