sleeoffroad
Supporting Vendor
In preparing to take the ShortBus on the Ultimate Adventure from Petersen' s 4Wheel Off-Road http://www.4wheeloffroad.com/2006ultimateadventure/ we decided to get rid of the power steering issues that have always plagued the ShortBus.
Decided to go full hydro
Using PSC components we have ditched the stock pump in favour of a high pressure/flow pump mounted where the idler pulley used to be for the AC belt. The pump acts as tensioner. The gear on the original pump was removed and the pump was re-installed with plugs. Now I have a spare 1FZFE for someone on the trail
We are still working on the bottom outlet port to get it more tucked in.
We had custom hi-steer arms machined that are prototype for production units. This in conjunction with a RH steering arm allowed us to install a double shear arm setup. More details on these arms will be available later once we have tested it and made some changes. This will be good news for people swapping 80 axles into other projects.
Double ended ram with custom links does the pushing. 1 finger steering with 40" tires. We still have to add a little tube protection to the ram area.
This is a little bit hardcore and really only intended for the off-road only crowd, but it does open the door for hydro assist for others that are more on-road/off-road but pretty hardcore.
Wish us well, we are leaving next Friday for the UA and hope to have a really fun time behind that FJ Cruiser with 39" BFG Crawlers on Dana 60's.
