HJ47 welcome here? (4 Viewers)
here's some more. in picture three I am starting to feed the new switch wires in towards the terminal block
I also got four of those 18mm allen head plugs that SOR sells as drain plugs. They have a little magnet at the bottom.
I installed two into my differential housings, and two into the intake manifold :eek:
to replace the ugly rusting bolt heads that were there, in turn replacements for the glow plug current sensor and other gizmo from the yanked-out Superglow system. The new ones look much better in there, that's for certain!
And finally, here's the wiring harness, all pulled out and in need of a final wrap.
And a couple of minor wiring bugs are yet to be solved: the wiper, and the light dimming rheostat, so I'm planning to try and solve them with the harness out of the truck. it will be a simple matter to hook it up to a battery if need be.
Little trick I learned when restoring, you can use a very soft bristle brush wish a gun wash in a cup. You dip the brush and drag it smoothly across the freshly applied seam sealer and it flattens out super smooth, might be a little late for that tip.
I did that sort of thing with the seam sealer I put along the inner lip of the doors. I have also read about using a couple of strips of masking tape on either side of a seam, then putting the sealer down, wiping it with your finger, and then pulling the tape off to leave a clean line.
I was trying to duplicate the factory bead of sealer, which is put on in a smooth pass and left as a rounded bead, not wiped in down and flat - not that there is anything wrong with that mind you.
Here's some update pictures:
i only loosened the nuts at the injector end, as the nuts on the pump end seems frozen to the injector pipes and i didn't want to find out the hard way, if you know what i mean.
After the pipes were out of the way sufficiently, i used a pair of wrenches to remove the nuts which hold the distribution pipe. another piece of pipe which i knew to be costly to replace if damaged, so I handled it most gingerly.
and finishing up by putting the lines back on, with the nuts left a bit loose for now. The system need to be bled before start-up.
Bottom two pictures shows my solution for sealing the holes in the cab floor for the pto gearbox lever. The grommet is from a BJ40 firewall.
