And then I put the glove box tether/cable (it's been 'lost' for a month) on the powder coated pocket door panel.
I'd like to get all the sheet metal into epoxy primer by the end of the month, and just want to make sure I have drilled all the holes I need before. There will be three coats of primer at least, so I will still have opportunities to modify stuff.
One small job that remains involves the ill-fitting passenger side fender, which needs repair to the running board mounting, and needs to be converted into a proper LHD fender, which means the bent sheet metal piece to allow for placement over a steering box (the fender is originally from a RHD truck after all) needs to be removed and replaced with an appropriate straight piece. I'm not really sure if I should bother actually, but probably will all the same.
A whole bunch of money remains to be spent:
-two more tires
-possible re-core of the radiator
-shock absorbers all around, and have no idea what to get at this point. I'm leaning towards OME, since I have the Dakar springs, but could change my mind.
-steering damper: what about that return-to-center type? Stock 40 series part? Stock 70 series and move the attachment bracket? O.M.E? H.F.S/B.D.S. from CCOT?
-tie rod needs to work with 60 series TREs; drag link needs to connect to 40 series pivot (small taper) at one end and to the 60 series TRE at the other.
-clutch and brake lines need to be made
-I need to sort out the pto drive shaft mountings, and look more into the rear pto drive possibilities, which would require another three-section pto driveshaft from a 60 series
-paint, bed liner, filler and othe autobody supplies will likely eat $750
-rear window glass is needed
-a correct length speedo cable and parking brake cable are needed.
-restore front driveshaft and install new u-joints
-the seats are abysmal -I need to get a better set or have mine re-done. it looks like I need a passenger side bucket seat at a minimum
-a tuffy box is needed along with a conventional md/cd compatible deck/amp.
I was thinking too of alternative paint schemes, and what do y'all think of this: 857
NORDIC BLUE exterior and interior with a
SILVER roof and bezel, which happens to go along with the silver instrument cluster housing, tach housing, and pocket door lid. The truck would therefore be:
BLUE/SILVER/BLACK
The silver would probably realize the same beneficial cooling aspects as the white, as far as the roof panel is concerned, and silver and blue do look good together, and it would mean fewer colors, which is less 'busy'. Any thoughts? Hate it? Love it? Who cares - just throw some flat black on everything?
Ahhh Friday!
