HJ47 welcome here? (3 Viewers)
more shots of mangled parts, and the sad task of pulling the engine again...
I've never seen such pounded-on rocker tips before. God knows what they would have cost from Toyota to get new (not that the local dealership would have been any help in that regard...).
The tranny just needed a new gasket and seal. I took the flange off and wire-wheeled it, then painted it (visible in lower left of tranny pic). Just waiting on a gasket and seal shipment from SOR and it will be back together.
Another thing I discovered when i pulled the head was that my engine was not an early 2H with cylinder liners, but rather a later 2H, with a parent bore block. That explains the oil cooler cover and the non-fitting oil filter bracket.
I managed to find another 2H in a wrecking yard about an half hour's drive away - not a common thing to find by any stretch. The wrecker said it was the first one he'd gotten a hold of in years. It was out of a 1986 HJ60. The truck was in garage-kept, rust-free condition, and by the general lack of dirt on the negine, had evidently seen little to no off road use. Too bad it went into a ditch over the winter and was written off. It was from Victoria, on the south end of the island, where snow is a rarity. They don't even have snowplow trucks there - or at least not in the recent past.
Another good sign was the presence of Toyota oil and fuel filters, which I thought probably indicated a dealer-serviced truck. The rig had 325,000 km on it (slightly over 200,000 miles), and started up with a small puff of black smoke. After that, it ran cleanly and smoothly. I snagged it for $2000, which included the 24 v. starter and alternator. I needed the air filter housing, which had a K&N filter in it, along with the vacuum tank reservoir, so I let the yard keep the alternator. They also let me have the brake booster for $35 and pull whatever parts I needed from the electrical system. Since my truck is 12v. and I want to stick with that, I won't be able to use the starter, so I will post it up for sale.
Here's some pics, the first showing the truck the engine came out of. This engine, though only a year different than my dead one, had many differnt features. The injector pump does not use an EDIC system, rather a vacuum shutoff (hence the need to obtain the vacuum reservoir from the truck). I don't mind loosing the EDIC system, since I'm all for reducing electrical complexity in my rig. The accel. linkage also has a secondary lever arm that pulls the curved arm, pulling in turn a cable that goes to the auto trans. I pulled that bit off today. I'm hopeful I can find a good solution to the accel. cable, since it is much shorter in the 60 series than in the 47, and has different terminals swaged on the ends.
Notice the timing gear cover is different on this engine than the dead one: this is the form for the cover when the engine came from the factory with A/C and/or P/S. Another difference is that the crankshaft pulley is the harmonic balancer type, so it ought to make the engine a tad smoother.
In the second picture you can see that i have mounted the 47 series power steering pump, and have removed the crank pulley. I found a leak at the back of the timing gear case, but I would need to pull then engine completely apart to remove the case, so I think, uh, not. I can put up with a minor leak, and will try cleaning the area and using high-temp silicone to effect a short-term repair. In the third pic you can see the engine mount from my 47 installed, which is part-and-parcel of the power steering pump assembly.
Another couple of pictures of the new 2H. The first shows the rear of the motor, where i installed a new crankshaft end seal. The aluminum carrier was not wanting to come out easily (Edit: I later realize that the normal approach to removing this part is to take the oil pan off first, which gives much better access to the bottom of the retainer), so I pried the seal out with a screwdriver, taking care not to scratch the crankshaft, and pushed a new one on with a liberal amount of non-melt grease and tapping it home with a wooden block.
Then the left side. This is after a good scrub down and cleaning. There are some minor leaks here and there, but nothing too bad, and I'm attending to what I can get to without taking the motor apart. In the left picture, there is a sender of some sort installed at the back of the block. I'm not quite sure what it does, though a friend suggested it was a low-pressure shutdown switch.
And here's a couple of shots showing the small amount of progress I have made with the cab floor. I obtained a chunk of copper plate, and by using it as a backer, I have been more easily able to get decent welding results.
The second shot shows the two parking brake mounts under the floor. I have opened up the hole on the lower one and will soon weld the smaller one (top one in the picture) closed.
Well, I've made a bit of progress on the engine. Put the mounts and tranny support brackets back on, changed the filters and rocker cover gasket, cleaned the rocket cover, and pulled the water pump to clean and paint it. I've also put the new water pipe and hoses on, and changed the glow plugs to the slow type. Installed new temp sender. Cleaned and painted the crank pulley. Cleaned and painted the rear engine blocking plate, and installed the flywheel. Installed the 12v alternator and will hook up the hoses soon. Replaced the heat shielding on the exhaust manifold as a final step.
Waiting on the pilot bearing and tranny seals and gasket to come (should be any day now) and then i can put the tranny back on.
There's a minor oil leak emanating from the timing gear case just below the water pump, and I'll be cleaning the seam between the casing and the block with acetone and using high temp silicone to seal it as best I can.
Thanks Dan - I'm looking forward to one day reading your rebuild thread too!
I keep chipping away at this project. I stripped the rear axle right down yesterday. Two of the hub nut lock screws had damaged phillips heads so I used a LH twist drill on them, and it worked like a charm and they pbacked right out. Now I need to get some new ones - hello SOR.
I discovered that the right hand side rear brake drum wasn't in great shape, and that the left side had suffered from a wheel coming off and pavement drag at some point in its life, and had a good 1/2" ground off the drum. Another fun part to replace. I will be completely rebuilding the brakes, replacing bearings, getting a new drum, etc, in the coming weeks. I've wire wheeled, primed and painted the two hubs and one of the backing plates so far.
I pulled the surrent sensor and resistor off the engine intake manifold and plugged the holes with 18 mm x 1.5 mm bolts, with copper crush washers under the heads to seal them.
I had the steering pivot support plate welded into the chassis by an experienced commerical welder, and have since plut the reconditioned pivot assembly back on the chassis.
I took the restored vacuum reservoir off the chassis, thinking of using the 60 sereis one, then changed my mind and have replaced the unit back on. It's like musical vac reservoirs. Hopefully that's over now, as I'm getting dizzy.
Still waiting on my SOR orders, which are in the mail. The CCOT parts (front windshield weatherstrip and greasable bushing set) came yesterday, and my OME srping package should be on Vancouver Island by tomorrow. The anti-inversion shackles are in sea mail transit from Australia -hopefully they will show in the next week or two.. I have another aprcel coming from Australia as well, containing a new windshield washer reservoir/overflow tank, along with a few other bits.
Contemplating breaking the transfer off the tranny to do the seals and gaskets...
...endless...and soon, pennyless...:rolleyes:
I wonder if those rear brakes on your FF are the same as an earlier FF? I have s***loads of drums and shoes and stuff kicking around. lots of it new....
Holy sh*t, you read my mind SeaPotato! I was looking for your phone number to ask if you had any drums kicking around (given that you have gone to 4wheel discs on your BJ45, I figured you might). The rear rums on mine are single wheel cylinder, and the shoes are about 2.5" wide. I had hoped I could swap my front drums on, but they have 3" wide shoes and the double cylinders. So yeah, if you've got some brake stuff, i could be coming up for a look-see real soon.
Today was a good day. Even though it sucks to be in debt with this project, the good news comes regularly with packages of shiny gear. Today was exceptional in that regard.
In came the OME springs, heavy front and medium rear. In came the SOR order with the gasket and seal for the input shaft cover plate. The seal was a bit difficult to remove, and to put back in (the SST would have been nice to have), but it went in, got slathered in non-melt grease, and the cover plate's bolted back on. I need to get a torquewrench to set the bolts tomorrow.
I also had improvement in my welding today. The little section of floor section was stitching in today - the piece on the right in the second photo. By lowering the wire feed speed, moving the heat seting up from 2 to 3, and using a copper backing plate, I have been able to get much better penetration on the welds with no burn-through. I'm psyched! :bounce:
A firend of mine, another Mudder, welded a new section in to one of the step mounting brackets.
One of my rear drums had a cylinder leak, and the other had suffered from not one, but TWO wheel eject and run drag sessions (I presume - then again, maybe it was dragged by towing, and the guy didn't care about the missing wheel?). After pricing out a new drum, and factoring in the shoes, and spring kit, and re-machining the other drum, i have realized that what I have here is a good opportunity to convert to rear discs, and that is what I will be doing. So, I stripped the rear axle completely, and dropped the springs from their perches.
I'm still waiting on the anti-inversion shackles from Oz to arrive, which at at sea at the moment. I can't wait to get them!
I've got a little more done on the engine, cleaning the fan and reinstalling it along with the belt and pulley.
I pulled the current sensor and resistor (shown in the second pic) and replaced them with 18mm x 1.5mmthread bolts with copper crush washers underneath. A cleaner choice might have ben to get some diff drain plugs, which i think are the same size threads but have much more svelte heads on them.
Tomorrow I should be able to acquaint the engine with the H41 tranny. I'm probably going to pull the transfer off and attend to the seals within. It seems logical to do it now, and the hose running from transfer to tranny indicates that the main seal is probably not functional.
Today i hunted down some electrical bits and pieces at the wrecking yard, and put in a couple of hours on the 47. I cut the u-bolts on the rear springs to free the axle. Then I sandblasted the anchor plates, primed and painted them. Then I wnet at the spring mountings on the frame with paint stripping disc, wire wheel, flap wheel and a touch of sandblasting (then I cursed it real good :^)), then sprayed some rust converter/primer-sealer on. Excuse the dark pictures. The third one is that side step mount that was repaired. It's going on the truck tomorrow!! (hey, ya gotta take your small victories where you can get them!)
