High lift jack alternatives. (2 Viewers)
Hi-Lift states ~175-lbs of force to lift the rated 4660lb, so more like ~165-lbs at 4400lbs (note the top 12" of the 60" are only rated at 2660lbs per Hi-Lift). I think their rating is assuming a pull from the very end of the handle, gaining the most mechanical advantage, which is not always practical or safe. Worth noting the ARB only goes to 48" so the reduced 2660 load of the Hi-Lift at 48-60" is still a win. That said, I've never believed there is a 2000 lb capacity loss from 48" to 49" on the 60" Hi-Lift, simply can't math. They are all 'Rated' at a lift of 4660lbs 'and tested' to 7000lbs, so think of it more like a WLL/SWL and MBS/MTS relationship. Note that the shear bolt (they call safety bolt) is designed to fail at 7000lbs which is still before the climbing pins or other parts fail, which could/would drop the load. I.e. it shears and stays put. I don't have a handle force number on the ARB but I'm going to guess 50-60 lbs @ 4400lb. Easy enough to test if I get a minute.
With the Hi-Lift, the human operating the jack is the only thing keeping that 170 lbs of force from clubbing anything in it's way as it is in between engagement of the climbing pins, hence why they can be very dangerous when used incorrectly. Ever seen a Hi-Lift auto ratchet the entire load to the ground with the handle flopping back and forth faster than your eyes can track. It's a fun class demo :D The hydraulic high range options, the Tauler, etc all wouldn't have handle feedback if you slip or let go... or simply can't physically push down harder.
I use straps to limit suspension movement regulary. On my SOA FJ40, I only carry a 48" High Lift. I can quickly strap F/R axles on one side betwen the frame and the axle housing and lift from the slider to bring both tires off the ground.
Oh yeah. I broke the windshield out of a old ex FedEx box truck we had many years ago changing a tire with a high lift. Let it go on the way down and the handle flew off about 20 feet in the air and came down right in the middle of the windshield and smashed it up pretty good. Didn't go through, but totally ruined it. I haven't thought about that in a long time. There really should be a safety mechanism to stop that. Something like a coat over the handle might be enough. You might be convincing me of the value of a safer jack. A windshield or a door skin replacement starts to cancel out some of the savings of the high lift...
For limit straps - now I'm thinking I should maybe have one. What are you using for a strap? I think a "whoopie sling" from a piece of uhmw rope that can adjust to the front or rear shock would be a good way to go that wouldn't weigh much or take up space and could be easy to install and remove. Plus they're just kinda handy to have around. I keep a handful on my sailboat for general use, but never really put any in my offroad vehicles. Can also double as a soft shackle if you use big enough rope. I think we're going to have to rename them before they get any traction in the offroad world.
Not sure where whoopie sling came from, but that's the only thing I've ever heard them called. Maybe just "quick adjust rope loop" or something? haha.
It should be easy to just put the loops around the top and bottom shock mounts on pretty much any rear Toyota axle. The IFS is a little trickier because of the leverage ratio - A heavy 700lb/in coil compressed 5 inches would mean 3500lb of tension while you worked on it. And need to find a good place to loop around from the top hat down to the LCA where it's not going to be on sharp corners.
...There really should be a safety mechanism to stop that...
Agreed. I modify all of mine to take a hitch pin. It won't stop the machine gun auto-ratchet but the handle won't land in the glass :D
They come with a cotter pin but it's nice to be able to quickly/easily remove the handle and use it for other trail needs. Cheater bar, tie rod or pitman arm sleeve, baton :D
What are you using for a strap?...
I use a 10k ratchet strap, I've removed all but maybe 5' of the strapping so it packs small/easy. I can cradle the axle (or control arm) to the frame or do a loop if access allows. Most IFS vehicles don't have 5" of compressed spring at ride height, the typical 100/470 has more like 50-70mm so they don't always need as much limiting.
Hey @Romer, would the Mojab mountimg clamps work with the ARM jack? I’m trying to find a location and method of mounting the ARB in my 200 and noticed the Mojab mounts you used on your Taco. ARB doesn’t have any similar mounts that I’m aware of.
Not sure. The body part would work for the lower end, the one where the handle is may not. When I mounted mine horizontaly I used some synch straps I had screwed down to top of my drawers. I have the Slee ARB mount now on my bumper
Thanks. Didn’t know Slee made something for the ARB Jack. Not sure how well it would work on my Dissent swing out but I may be able to fab something similar.
Also, any concerns with storing your Mojab jack horizontally? The only potential issue I’ve heard about is potential hydraulic oil leaking. I think the ARB manual says its best to stow it vertically. Horizontal would be the most convenient for inside the truck storage.
I stored my ARB jack horizontally for 5 years without issue. The Mojab jack has the shut off bleeder valve that locks. I am willing to see how it goes Horizontally since that worked on the ARB Jack. I missed the Horizontal vs Vertical part when I bought the ARB.
This is how I stored it for 5 years
This is how I store it now. Only drag is it is exposed to the weather
Here is my Mojab Jack in the Tacoma
I could have just been lucky with the build of my ARB Jack, so I am hesitant to make a recommendation on Horizontal vs Vertical, but Horizontal worked for me without issue.
The Mojab in the Tacoma may never see use since the 200 is my main wheeling vehicle. If I was replacing the ARB in the 200 due to failure of the jack, I likely would have gone with another ARB due to the long history. I set up the Tacoma for close by easy trails if I wanted to take it. The 200 is a much better offroad vehicle and that is what I expected when I bought the Tacoma which is primarally my daily around town daily driver. I could have gone without building the Taco, but what is the fun in that :)
I did use my high lift on Saturday. Went out to the local glacier in my side by side and something felt a little off with the trailer. Subtle, but could feel something. Checked the tires and sure enough one wheel bearing was loose. Like really loose. Grabbed the high lift off the sxs bumper and used for lifting the trailer to reset the bearing preload in the parking lot to get home. Trailer is only 2 years old. 👎
Anyway - maybe one of the few places I feel safe working on a high lift supported vehicle. Weight trailer connected to a 6k lb truck lifted 3 inches off the ground.
Stumbled on this:
Extreme Max 5001.6399 Universal Heavy-Duty Extended Range Quick Lift ATV/UTV Field Jack with Large Foot Plate (8" x 6") - 26" to 36" Range, 2500 lbs. Capacity https://a.co/d/8Y7tz3N
Used the tauler jack for the first time to help a buddy swap an axle. Works awesome with fine control.
I went to go buy the ARB Bushwacker X-Jack and discovered, while it is sill listed on many websites, it has been discontinued by ARB and no one has any in stock, except maybe Amazon but the Amazon one is now $530. So, I’l going to roll the dice with a cheapo knockoff. Anyone have a knockoff that they like? I’m probably going to order this one:
ALL-TOP Off-Road Exhaust Air Jack, 31inch Lift 8800Lbs Capacity, Inflatable Soft Jack for Low Clearance, fits Air Compressor & Exhaust https://a.co/d/3PqytUe
Also check the ATV sites for knock off's those guys always carry them. Think it's a bunker?
I have the badlands 3 ton off road jack. I wanted a floor style jack. With the knobbie tires I’ve had no issue using it in sand, dirt, and rocks. The saddle extension gives almost 30” of height. It takes up a little more space in the back but for the piece of mind it’s worth it to me. I picked it up during one of HF’s sale coupon weekends for about $220.
is that badlands jack worth $400? how do you like it?
I paid $230 on sale and with a coupon. For that price it’s been invaluable. Yea it’s big but I ratchet strap it to the back and I hardly notice it. I originally put it back there cause the wife was complaining there were too many jacks and stands in the garage. But honestly it lives back there now. Used it on off road trips and moving trailers at the racetrack. It rips. Also being a 3 ton I never really worry using it with the 200.
dirt lifestyle nate did a side by side comparison with the pro eagle and it appears they are quite similar, to the point they probably come out of the same factory in Taiwan. However the service from Pro Eagle is what you’re paying extra for.
