Well my cruiser is now idling at 1600 -2000 RPM's after driving it and putting it into park. In all other gears, idle drops back down to 600-800 RPM range.
At first I thought it was due to high outside air temps of 95 F and hot intake air temp of 140 to 155 F & high water temp in the 190 to 205 F range. I thought that the ECU was having it idle higher to recruit more airflow from the fan. However, on a cool, wet 70 degree F morning it is still doing the same thing!?
Has anyone had a similar occurance & would care to share their thoughts?
I did all of the following repairs at once with no driving in between. Any connections between these and the high idle in P and N after driving it?
- Replaced starter & alternator with reman's from CDan (due to starter contact being stuck and toasting starter. Alternator was putting out 17 volts so regulator was shot, probabally due to starter issue.)
- Added 1 qt. of Gunk engine build-up remover to oil (Castrol High Milage 5W-30, ran for 5 minutes then drained overnight and flushed with 2 fresh qts. of oil and drained for 5 hours, replaced with Castrol Syntec 10W-30 (as per owners manual for temps above freezing through 100+ degrees F) & a Toyota 90915-YZZD3 oil filter. (removed the same model # oil filter)
- Replaced oil pump seal & crank case seal
- New Toyota A/C & Alternator belts
- Drained and refilled transfer case with Mobil 1 75W-90 (6,000 mile change interval)
- Drained, flushed and refilled diffs with 80W-90
- Added 1/2 tube of grease to steering knuckles (bringing them to 3/4 full)
Also, replaced Throttle Position Sensor 3,000 miles ago with a new Toyota one.
