BTW, if you are gonna use the highlift to change a tire. Strap the axle to the frame with the suspension compressed. It'll make it a lot safer.
And, my cruiser on 35's still can use the stock bottle jack without headache. What OEM jack can't clear a 30" tire?
I used steel because I wanted to weld on to it the supports that go where the wheels used to be. I used the Core-10 because that is what was laying around. It being an abrasion resistant alloy is great, but the odds of wearing out plain mild steel aren't great.NTSQD you have got me thinking if I were interested in making a larger baseplate for a jack stand would you recomend using a similar metal or could 3/4" plywood work? I haven't thought through attaching the jack stand for stability but the wheels are turning. I saw pics of the skid and jack in another thread where you posted and it looked really interesting. But not in the cards in the near future.
Maybe my OEM jack is broken but it wouldn't lift my 33" tire off the ground.
When your buried up to your axles in mud, a Hi-Lift looks pretty darn appealing, when your high centred and you need a little sideways push a High-Lift looks pretty darn good, makes for a decent come along in a pinch, I've used one to help straighten a tie rod once... they're not just for replacing tires.
Cribbing!snip.....
If the problem is not enough extension, you just need a wood pad to set it on.
Which is why I have the full length skid plate base.My dad and I once used an OEM Ford jack in an attempt to lift his loaded pickup on a hot day. Instead of lifting the truck up off of the hot asphalt, cranking the jack just buried the base of the jack into the soft asphalt pavement. Stuff was almost kinda spongy! A chunk of 2x12 placed under the jack base did the trick!
The rare mud that I encounter is nearly bottomless. I avoid it at all costs.When your buried up to your axles in mud, a Hi-Lift looks pretty darn appealing, when your high centred and you need a little sideways push a High-Lift looks pretty darn good, makes for a decent come along in a pinch, I've used one to help straighten a tie rod once... they're not just for replacing tires.
Close!Is that the moon?
