Two days ago I did quite some measurements and checked a lot of components. I printed out the AHC part of my FSM and started work on page one.
After every measurement I wrote the value Ohms/Pass/Fail in the FSM and went through the pages. I will post my progress and page numbers as it could help others.
First thing, check DTC’s: None.
After that I wanted to perform the “INPUT SIGNAL CHECK”. I hooked up techstream, selected the input signal check and got an error: 0x91020324 “It’s possible the requested function will work if you try again. If the problem persists please submit an error using the F12 key”
So… that didn’t work.
After that I just performed the check myself. Open up the data list in techstream and checked the signals listed in the FSM (on DI-211):
All inputs were correct, and according to the table they were good. But there was a thing that was strange.
When my wheels were straight the steering angle sensor in techstream does not give 0.0 degrees but -492.75. Also when I turned to the right techstream stated 153 degrees, fully to the left was -1145.40 degrees.
I do not have or had a trouble code that included the steering sensor. But I decided to look at the DTC 1781/81 page in the FSM (on page DI-265).
There the steering angle sensor is described as a incremental encoder
Then I checked the inspection procedure on page DI-267:
When I use techstream the value changes. But when I measures SS1 and SS2 with my multimeter I got different values. On both terminals I got values of 0.33v or 10.54v, obviously not good.
So we move on to page DI-268:
There was a voltage of 12.18v on pin 1 & 2, so this is a pass and we move on to step 3.
I did not apply separate power to the connector as described, but used the plug where the power of 12.18v was present. The resistance I measured was 3.7 to 3.9MOhms and was not changing from 0 to infinite. So according to the FSM I’ll have to replace the steering angle sensor.
Is there a way that this error would cause my AHC problems and prevent the system from being active?
Like the system not functioning, no DTC’s, no running pump, no warning lights, giving step values of 0?
After this I went on with checking the separate parts of the AHC system to make sure there are no other broken parts.
We move on to the height control sensor circuit. I just replaced all height sensors and gave the linkages a fresh coat of paint after stripping the rust. I adjusted the linkages and the values that I get in techstream are correct and change accordingly. I’ll see this as a PASS.
To check the fluid pressure sensor I measured PACC (pin 4 of connector s8 on the AHC ecu). First I measured in idle state, the voltage was 0.49v. Then I started the pump by jumping the relay, when the pump got pressure I measured 4.19v. I’ll see that as a PASS.
Time to check the temperature sensor. I measured ”TOIL” (pin 3 of S8), Voltage 2.16v, that is a PASS. Max 2.4v at 20 degrees C in FSM (page DI-218 for the pinout of the ECU and DI-233 for the temperature sensor).
Now it’s time for the interesting stuff. The damping force control actuators. First of all I checked the connectors again. All connectors are nice and clean and not damaged. After that I measured the coils of the stepper motors inside. I measured as in the picture below (FSM page DI-238).
All coils on ALL motors were 12.6 Ohms, so a PASS.
Next it is time to check the cabling to and from the actuators. You can find the schematic on page DI-237 of the FSM. All cables going to and coming from the ecu to the actuators measured 0.8 of 0.9 ohms. No open or shorted connections. So all the cabling to and from the actuators is good.
I did the same thing for the control valve assembly. You can find info on this unit on page DI-239 of the FSM. The pinout of the solenoid assembly is on page DI-242 of the FSM. All coils measured 3.6 Ohms. While I was in there I also checked the solenoid on the accumulator (big single thing, not to be confused with the four damping force control actuators. This coil also was 3.6 ohms.
I also applied 12v power to all the 5 coils (valve body 4x and accumulator 1x) and they all click nicely.
All cables between the solenoids and ecu are good. They all measure 0.7, 0.8 ohms.
Next to the AHC motor relay circuit. More info on page DI-243 of the FSM. The relay itself clicks, engages and disengages and is ok. The wire running from the ECU to the relay to switch the relay measured 1.4 Ohms. And there was 12.18v on the switched contact (one side offcourse).
Same thing with the main relay. Relay works, clicks and has continuity. All cables from and to the main relay seem to be ok.
I did not have time to check more. But all the parts until now seem to be OK. EXCEPT the steering angle sensor. That gives strange values. Could it be that the ECU probibits the function of AHC because of a faulty steering angle sensor?
I’ll be sourcing this part. Maybe first prepare more checks on it or take it apart.
