uHu
Bridgeburner
It's time to locate the ahc ecu and check the connections to the different actuators. With the amount of corrosion under there, it wouldn't be surprising to find a missing connection.
Another piece of advice is that trouble codes and symptoms are not always logical on the ahc system. Because of a faulty rear sensor, I've had 1: front at max height, 2: front on bump stops, 3: a number of different codes that all disappeared with a new sensor, just as an example.
What is the production month of your cruiser? The FSM pages differ a bit over the years. And also the Active Test, iirc.
