JohnnyC
Long ago TLCA# 2231
Can we see some pics of your setup?
x2 ...i love pics
x2 ...i love pics
How hard is it to install? If Jason can unhook it easily, it would be a good test to see him take it off his cruiser and put it on one of yours for a week or so and see the results. I think you could make one yourself for a lot less.
I was going to try just hho at first just to see what would happen......how much it produces etc etc.I built the generator part myself with no specs just out of stainless steel outlet covers bolted together with nylon bolts and seperated with nylon washers just to see how flamable it would be and you can light the bubbles and they sure do pop. A local 4x4 guy here in town is looking into it. I am a skeptic also there has to be a way to retard the gasoline intake and regulate the hydrogen into the motor. It almost seems like a carb motor would work better. I am still interested in seeing more results from real people. I have also heard of just using only hho to run.
Facts you should know...
It’s not the HHO that makes the engine run. It’s what the HHO does to the inefficient gasoline concerning combustion efficiency. Gasoline is but only 13% efficient on average when it comes to actual power produced by the combustion process. Adding an additional fuel [Hydrogen] and oxidizer [Oxygen] "aka HHO" causes the inefficient gasoline to burn at a rate of better than 95% efficiency. .
ok fellow cruiser we @ candograge have read and reread alot of different idea's and design's of a hho generater ............... so we built one the 5 plate using stainless steal blank switch plates we got from home depot feeding the plates with a 12v power source we did produce hho ( very explosive ).......installed one on a 05 dodge cummins truck...... black smoke the use to come out of the tale pipe is no more and the mpg and power did get better we have found we need a larger cell for this truck ............... as soon as i finish rebuilding my 2f i will install one ............. I have an problem with introduceing the hho into a vacumme port under the carb,cause when you give it pedal the vac drops off i think i'll feed the engine from above the carb "ie " the air cleaner just above the carb it's self will keep you informed on the project................... chk out you tube " hho" i might even try using the "FISH CARB" that my late uncle bought many years ago from a place in daytona fla. and left it to one of my older brothers when he past 20 some years ago ................... keep it up...good luck ... and remember you "cando " it ................................ john
What?
I will also correct you about the 99% efficiency of the combustion process. You can't measure it by HC emissions alone as many of the HCs are burnt up by the catalytic converter.
In addition, how the gasses explode, not just how complete they burn would have an effect on how much usable energy you would see at the rear wheels.
Lets see what I can do with thisAs per Crazy's request.
Hello fellow cruiserheads. Those of us working(?) at Cando Garage (?) have read a lot on different designs for HHO generators. We have built one, it is a 5 plate design and we used blank wall switch plates from Home Depot as the source stock. When we feed 12v to it, it did indeed produce H2 and O2, and we found this to be very explosive![]()
We used a 2005 dodge cummins diesels as the testbed for this set up. While it reduced the production of black smoke (over fueling) and we noted an increase in milage, we feel that this unit is too small for the application.
I am rebuilding a 2F, and when done, I plan to build a HHO generator for it as well. The problem I see with this it that the vacuum available downstream of the carb will decrease when the throttle plate opens, and thus provide an inverse signal (to what is needed to draw/produce more HHO on hard throttle) to the generator. So I am planning to hook the feed from the HHO generator upstream of the carb, so that the pressure decreases on throttle application, drawing more of the H2 and O2. I'll keep you up on how it works.
Youtube has some good stuff on HHO. I might try using a "Fish Carb." (that would stink, burning fish :whoopsthat my late uncle bought many years ago. Good to see others are experimenting with this stuff, keep it up! Remember, you Cando-it (play on name of business.....)
Cherry front drum brake.This puppy gets a bit better mpg than the toyota, it's a 600 watt 36 volt speed machine.
My '76 2F has a combustion efficiency of 99% and it has no catalyst. With a catalyst it would be 99.9%.
Hogwash.
The temperature at which it burns has an effect on the total energy released, but this is a relativley small component. This is the "TdeltaS" entropic part of the Gibbs free energy equation, but it is much lower than the deltaH (enthalpy or heat) part.
Gibbs free energy - Wikipedia, the free encyclopedia
PT Barnum: There is a sucker born every minute.
Well that is clearly BS. If it improved the combustion from 13% to 95%, you should be seeing much more than a 30% improvement in MPG. Your engine would probably also run at 120 degrees because you would not have the losses to heat. If there is legitimacy to these products, it is a shame that these sites are filled with more salesmanship than science. It is also why people like me are skeptical until there is some unbiased data.
I actually disagree with you on that. Having a properly tuned engine increases the efficiency. Your gains from a properly tuned engine may not be mutually exclusive of the gains from another product. For example, if you have fouled and mis-gapped plugs and replace them with expensive platinum plugs and your mileage increases 30%, you could say the expensive plugs are worth it because they improved your mileage 30%. But the fact is, you could have cleaned and re-gapped your old plugs or got new cheapos and seen the same gain. The improvement was not from the new product, it was from correcting the issue. So yes, you are seeing a 30% improvement, but you are getting the same mileage as a properly tuned LC. Now when you get it to give you 17 mpg, it is a little safer to say it is due to the new project.
Which leads me to another theory. I wonder if the issue is not the hydrogen, but it is actually the oxygen that is the bigger help.
Very interesting, but I still don't think anything has been proven (or dispelled).
Keep us posted.
