- Joined
- Oct 22, 2002
- Threads
- 168
- Messages
- 5,363
- Location
- Durango, Colorado
- Website
- www.durangomagazine.com
But these bubbles you can light!
I want to light mine like this
I am not a scientist, I am but a simple ski tech with a fettish for landcruisers and saving gas.
I'll provide as solid of information on mileage, running conditions, so forth as the project continues and the miles rack up. I may have a cross country trip coming up in it, so I hope to have more consisive results and figures soon.
maybe one i get my 2F-E stroker finished and broke in and im gettin steady mpg results ill ball up and take the plunge and see what it does since it would be a fresh motor...
or maybe ill just run propane...
I'd eventually like to convert mine to propane with the addition of hho. Do you know of any propane injection systems that run off of nothing but propane?maybe one i get my 2F-E stroker finished and broke in and im gettin steady mpg results ill ball up and take the plunge and see what it does since it would be a fresh motor...
I cut this from the manufacture web site: MagDrive Fuel From H2O - Tests Results
Facts you should know...
. . . Gasoline is but only 13% efficient on average when it comes to actual power produced by the combustion process. Adding an additional fuel [Hydrogen] and oxidizer [Oxygen] "aka HHO" causes the inefficient gasoline to burn at a rate of better than 95% efficiency. . .
yeap, I went from 10 mpg to 13+mpg in the first ten gallons, and it repeated in the next ten gallons. . . . Yes, my rig is not in pristine running condition, but its exactly the proper vehicle to test such a device on. If it can give me 30% better mpg and a smoother running engine and more power, then imagine what it can do in a properly tuned engine. . . .
Jason brought it by today. Looks pretty simple. I guess I'd better pony up for a system and see what it does.
When I first was checking out the different systems online, most all of them were for plans to build a similar system DIY style. I coughed up $49 bucks for the downloadable assembly of one of the DIY kits. It was to say the least, a bit overwhelming with 100 pages of detailed assembly instructions, with parts from radio shack that I was basically going to have to build a control module from scratch. This was new territory for me dealing with transistors,etc.How hard is it to install? If Jason can unhook it easily, it would be a good test to see him take it off his cruiser and put it on one of yours for a week or so and see the results. I think you could make one yourself for a lot less.
I continue you read threw your thread on this subject and as you all know fuel is eating at us cruiser owners so if you would not mind what did this kit cost you? It looks simple from what i watched of the video but even if i would get 2 more mpg's out of my 62 i could justify the cost of this thing....even with the wife....oh i can use this on fuel injection correct?
Any help would be great....reading on
