oops, my bad the turbo came with the 1.0 Bar spring yellow.
yes, you right looking at my old thread I had a crack in the housing and I couldn't build boost past 18psi using silver spring 2.0Bar.
I've identified a few factors why I can't build boost
1. crack in housing
2. air filter restriction
so new turbo is in I went down to the Red Spring and I'm making 16-17psi now.
I checked I have the red spring in there now 1.7 Bar RED set with the default preload set 2 turn/1.5mm
I do have a 2 Bar spring Silver I can try next that is the heaviest spring I have to try next I guess if it's not enough to reach 20+psi I could start doubling up the springs just like what you did. I could also pull the hose on the wastegate and see if that does bring me up past 20 but that method seems kinda risky
I did buy a box of springs that goes from 0.5 to 2.0 Bar just to experiment with
but could more fuel also bring up boost pressures?
I found your post here saying you had to keep feeding the fuel screw to reach 21PSI
This is my next move too since EGTs still low
it could also be that Kinugawa spring rates are out of wack. 1.7 Bar = 24.6 PSI
I would think with the red spring installed it wastegate should open at 1.5 Bar according to the chart
