So, just finished a WP install and started a coolant flush, and upon startup and first drive I’m overheating. Here’s what happened:
- WP bearing seized. Caught it immediately (was in my driveway - whew!) and replaced the WP with an Aisin WPT-029.
- Also changed the thermostat with an Aisin THT-007 and rebuilt the thermostat housing with new sensors and gaskets. Thermostat installed with the spring side facing down (pointy “bridge” facing up). It actually won’t go in any other way.
- changed a couple of hoses
- changed all the belts
- fan clutch works and fan is turning
- the 1.5” hose on top of the thermostat housing is hot, suggesting the thermostat is open and there is flow back to the radiator
I drained about 2.5 gal of coolant before I removed the WP, and currently replaced it with about 3 gal of water + Prestone Flush & Cleaner, so I’m assuming no large air pockets. I cannot get any more into the radiator.
At idle, temp gauge fluctuates between halfway and right up against the red - depending on whether I’m running my heat. Driving 30mph the needle almost reaches red.
In the entire time I’ve owned the truck, the temp needle never went above 1/4. I assumed it was a faulty sender, so that’s why I replaced everything in the thermostat housing.
So, what am I missing? Is it normal to spike like this using water? When I drained, I assumed another 2.5-3 gal of 50/50 mix in the engine, so I’m actually running a very diluted coolant right now for the flush, not straight water.
