I took the photos before tightening everything down. Everything is tight and torqued to spec. The photos were intended to show the double-double CV joint. I was going to take a pic of it on the ground but was too excited to put it on and drive vibration free. Wish it was loose because that would be an easy solve!
good to hear. With the drive shaft not bolted on tight it's hard to get a good idea of how aligned the pinion flange is to the t-case. If multiple drive shafts, some who have been proven to work, haven't worked on your truck it is likely a pinion angle alignment issue.
In my opinion, If you want to keep AWD and not have vibrations you have to settle for a lift height and solution that provides that. Otherwise part time the t-case and do what you want.
