Help finding part (1 Viewer)
Oregon
Yesterday my 100lc was running very rough and I got a cel for a cylinder 8 misfire. I thought I would just go change the coil but when I went to change it I found the cable that connects to the coil was very loose above it where it connects into the wire harness. I pushed it black in and the misfire went away. So I need to find this cable because the clip is broken. I will attach a photo it is not the coil side, it goes into a blue housing. Please let me know if you have any advice or if you know the part number or name of clip. I’ve already looked though all the diagrams online I could find. Thanks in advance!
I have used (4) zip ties to hold connectors together,two parallel with the connector and one on each end of the connector.
Get a magnifying glass and look on one of the connectors to see if there is a cast in part number. If there is....then add the prefix number below and see if it brings up your part.
