Help a member out (HAMO) (7 Viewers)
Does it still get to 200 even when its locked up?
Installing my RCV front axles starting Friday evening after 4:30 pm and Saturday morning 8amish. If anyone wants to join in the fun I'm at 12297 S Anna Drive Rockville Virginia 23146. 804-921-4890
May try to get over there tomorrow AM. Working tonight
Interesting, FSM says transmission temperature warning light doesn't come on until 302*F! Reset for light is 248*F. I take that as below 248*F you are OK. Perhaps I'm overreacting. Still going to change fluid.
Do you have to take your wheel off to use it?
Awesome thank you! I was also given a nice riv-nut tool by my neighbor for the club to pass around if anyone needs for something. Its the scissor handle type so you can really get a good connection
On a different note, my transmission temperature has increase around 15 degrees give or take 5 degrees at 70mph. I'm running around 210*F recently. On my trip to Hatteras at 70mph I was just below 200*F. On my trip to big levels when offroad, no temperature issues but this was the first time on highway I noticed it above 200*F. It seems it's getting to 200*F faster at highway speeds in the last couple weeks. I ordered transmission fluid last night. When I installed the Wholesale Automatic transmission nomad valve body, I changed the fluid at that time, 2 years ago. I am running through the cooler on the radiator and then to my PDI front mount cooler. I installed the blue hub radiator fan before my Hatteras trip. Reading I've done is pointing to my torque converter. Thoughts?
Rpms are higher now with gear change. Trans temps will go up to. Totally normal
Looks like Charles was dreaming in one photo. 🤣
It was a little bit of a show and tell without fully showing. Alans son was there so I had to keep it clean.
@Beach80 I’m working this morning until early afternoon if you want to swing by
