heater tube mounting location
Wheaton Illinois
Can anyone verify this tube mounts to the side cover holes circled in the picture? It lines up perfectly, but I am wondering if the tube needs to flip end for end. I say this because if I bolt it using the current orientation, the flange on the outside of the side cover would get crushed by the hose clip. If I flip it, it would put the clamp below the flange. Thanks, Mark
so if I understand, the two locations for the clips, are actually longer studs with a nut for the side cover, then a spacer and hose clip, then a second nut?
Thanks
At least on mine it's only one nut holding both on. Stud then the side cover-->hose clip-->nut
I'm sure there's a parts diagram out there somewhere that shows it
S.O.R. pic shows spacer (#31), but not much else.
