heat shield mounting opinions welcome
Honolulu
Looking to fabricate some exhaust heat shields. Two seemingly obvious questions come to mind.
  1. What material for the shield? stainless = low heat transfer but stays hot longer once heated; aluminum = high heat transfer so less effective of a barrier(?) but holds heat poorly
  2. where to mount them? to the heat source ie the exhaust pipe/header; To the device to be protected ie starter, oil filter and/or clutch slave
thank you in advance for your opinions!
Aluminum works best for reflecting radiant heat. Would be either mounted directly to the part to be protected or with an air gap. (glue aiuminum foil to firewall/floorboard, wrap harnesses/hoses/filter.)
If you mount to the hot part, stainless stl lasts longer. needs air gap on both sides of the shield in the area you're trying to protect
Why don't you wrap them with exhaust wrap and/or have the headers/exhaust manifold ceramic coated.
After reading you post closer, what engine do you have?
The starter should be on the oposite side of the motor of the stock F type exhaust.
  1. where to mount them? to the heat source ie the exhaust pipe/header; To the device to be protected ie starter, oil filter and/or clutch slave
Thanks for the responses.
bsevens:
Thought about wrapping the exhaust. Concerned about the wrap holding moisture reducing the header life. I have no experience with wrapping headers/exhaust. What is the maintenance related with it? As for ceramic coating; would rather get what life the existing headers have in them before replacing.
D'animal
Specs:
383 SBC, headers inboard of the frame rails, cross over 2 into one.
oil filter with in 1.5" of the exhaust (oil cooler in the system)
Starer; 2" or so gap btn the exhaust. Starter lopes after the engine heats up. Maybe heat related.
If I do one for the starter then might as well do the oil filter and maybe even the clutch slave cylinder.
"Air gaps" are in my future
