There is quite a lot of information in the Tech on cracked intakes resulting from stuck heat risers. However can someone tell me from these pics attached if mine is stuck open? or closed?. While exploring the source of a vacuum leak (13-14in) I got into looking for cracks in the manifold when I noticed that the heat riser is stuck , not surprised as it has sat for 13 yrs, however there isn't a bimetal spring attached to the opposite side of the counterweight. Since I live in the Bay Area in Nor CA the climate is fairly mild If this is stuck closed then I really dont have to worry about the excessive heat on the intake manifold and will just endure the longer warm up, however if it's stuck open then I would be more concerned, I just dont want to open that can of worms if I dont have to at this time. As you can see the manifold below the carb still looks good so I'm assuming that it may be closed but I dont know how long it was run like this either.
1970 FJ40 2bbl asian, stock, with vsv
