Hammer45
That connector is the fusible link. I posted the 60 version. But those 3 wires are the "fusible link". the idea being that in the event of a problem they fail and you replace that piece.Seth that looks to be a connector between 2 different fusible links. Or is that an illusion?
awesome tip! thanks. d![]()
FJ62 Fusible Link Fuse Equivalents?
I'm in the process of conducting open-heart surgery on my 3FE wiring harness and one of the things I want to change while I've got it opened up is to replace the 30+ y/o fusible links with something more modern. I've found a couple potential battery mounted power distribution boxes that might...forum.ih8mud.com
The colour chart in that thread is correct.
IF you decide to use a fuse, then I strongly suggest a MIDI fuse, they are designed to be slow blow and will mimic a fusible link. A standard ATO/ATC etc is fast blow and isn't appropriate for a fusible link replacement.
cheers,
george.
View attachment 2827344View attachment 2827342I’m learning that there are lots of ways to skin this cat. @ToyotaMatt sent me a new post with 2 ring connectors and a fusible link already in place. I think the supplied one is supposed to go to the yellow wire leading to the EFI. I suspect the blue which is a larger gauge will need to have the o ring removed then split into 3 wires to go into the larger triple FL. And the black should also have the o ring removed and attached to the large gauge white wire that I think goes to the headlights eventually. #1 is what I have on the vehicle and #2 is the new post sent from ToyotaMatt.
Maybe this thread will help:
FJ62 Fusible link wire gauges
forum.ih8mud.com
