Headlights not showing up
Lake Orion MI
I just purchased a 2021 with King 2.5 suspension. Supposedly raised just a bit in the front to give the cruiser a level looking stance. However, when driving at night, my low beams provide zero light. I mean its like they aren't even on. My guess is that the lifting of the front caused them to be too high even though it wasn't raised that much. But wouldn't the automatic headlight levelers compensate?
Another feature is that the headlights are covered in a clear protective film...could that be distorting the beam?
I was thinking of taking to local dealer, but thinking they may blame the ride height.
Your auto headlight leveling is moving them the wrong direction (way up), because the vehicle only has a sensor in the rear and your lift makes it think you are super light back there. You need an adjustable link for the sensor in the rear.
Better explanation here, plus discussion of solutions
What years have auto leveling headlights?
Honestly not even sure if my 2010 has this
2016+ LC.
08-11 are just static due to the not-very-sharp halogen beam cutoff.
2013-15 LC got a dial on the dash to manually adjust beam height, because the xenons have a sharp upper cutoff.
All LXs mostly take care of it themselves because of the inherent capabilities of AHC.
2016+ LC.
Thanks
I have a 2010 with the OEM 2013 headlights
Maybe I’ll look into retrofitting the dash adjuster switch into mine. The lights already have the motors. I was curious about that
Thanks
I vaguely remember someone working on that setup and posting about it. But I don’t remember any keywords to get you started. Just that I think it has been discussed.
Start the search!
I wouldn't call them auto leveling in the sense they know where the vehicle is at all times. You still need to set the base level, or the zero, if you will. From there, they will adjust as needed based off the sensor. The height is manually adjustable on the back of the headlights. Once you bring the aim back down you'll be good to go. High side of beam should be a 2-3" drop from center height of projector at 25 feet from a wall (on flat ground). I do a 1-2" drop personally.
Dangerous advice.
At least one user here ran the adjuster off the screw by trying to get their 16+ headlights aimed. That required replacing the headlight assembly, and it ain’t cheap.
Lifts on 16+ LCs needing the adjustable linkage to get the sensor back into normal range is well-documented in this sub forum. I strongly suggest OP research it before messing with the screws.
Dangerous advice.
You can only run the adjuster off the screw trying to lower the lights, it would not make a difference if user did it or the system did it via bracksts in the rear since the ride height is staying where its at. To actually have that happen and drop the projectors, the vehicle squat would have to be nuts. I have a set of 16+ headlights open right now and there is plenty of adjustment screw left to lower the lights from factory base setting (see the top screw).
OP most likely does need to lower the lights, between the front having been lifted (without the vehicle knowing about it) and the rear sensor being dropped out from the lift, which the computer will raise the lights to adjust for.
The “auto leveling” motors do their thing via the same screws as manual adjustment?
All that is needed is to grind a longer slot in the stock bracket that the sensor attaches to on the frame. Took 5 min with an air grinder. Then aim the headlights after that mod using Daniel Stern's website's guidance to align the beams.
Thanks for the responses. Would it be just as easy to adjust the shocks on the front maybe 1/2" to see if that brings them back?
Probably not, and it would definitely be easier/cheaper to address the rear linkage and aim the lights than to adjust the shocks.
For the record adjusting front king 2.5s still on the vehicle involves making a tool to do so. The included adjustment tools won’t work due to interference with the spring bucket while the shock is mounted to the vehicle.
