What started as a #6 cylinder HG leak and ended with a complete engine rebuilt on my '94 (thank you IDoug, CDan, and many, many others) is now done. The only unexpected casualty was the oil pressure sender harness. Below are some oddities that I haven't seen mentioned.
1. I was having zero oil pressure on the gauge. Backing out the sensor did not result in any leakage of oil around the threads. I was advised that a possible cause could be my having filled the oil filter prior to installation ("the mostly empty oil pump cannot build enough pressure to force the oil through the oil-soaked filter media"). Having replaced the oil filter with a dry one and removed the oil pressure sender completely, I proceded to shoot a stream of oil out the passenger side and over the tire, thoroughly coating my whole garage with clean oil. It is not clear wether the harness was the problem (it was VERY corroded) or wether I in fact had no oil pressure. Still, food for thought.
2. The front heater core attaches to the DS copper pipe with an o-ring and a little copper clip. Neither the o-ring nor the clip are available from Toyota (at least from my local dealer on a 2-day's notice). I reused the clip, replaced the o-ring and am hoping not to have to take the whole dash apart yet again.
3. I did the RT temp gage mod. Works great, with one caveat. Whenever I engage or disengage one of the difflocks, the gauge briefly goes to zero (cold), bumps around a couple of times and returns back. My difflocks are retrofit, with a 'custom' rear harness, so that may be a contributing factor. I am pretty certain that the indication is an artifact of the difflock switching and will study the diagram to see if the bulb or the relay could be influencing the temperature gauge. If anyone has seen anything like this and has any ideas, input is very welcome.
4. The pipe from the thermostat housing to the head (the L-shaped one that attaches to a nipple at the back of the water pump) was leaking at the bottom (despite all new o-rings). I had to resort to an oversize o-ring to stop the leak. More cooling system leaks (fortunately found *before* I put coolant in) were due to my having used silicon grease as a lubricant during pipe-to-hose assembly (all those connections at the firewall and the PS side of the head. Much wiping, cleaning and Breeze constant-torque clamping ensued. Be careful!
In conclusion, everyone is right. Buy parts from the 'mud vendors; farm out as little of the work as possible and only after careful negotiation (my block got cut far more than I wanted, the freeze plugs weren't done the way I wanted, etc... despite very careful discussion ahead of time); bag, label and photograph everything; search 'mud for the answers. Thank you, everyone!
By the way, the complete cleaning and overhaul did not cure my very low startup idle issue ( https://forum.ih8mud.com/80-series-tech/101950-low-idle-after-disconnected-battery.html ). I consider myself lucky that the solution remains simple and permanent.
