How do you tell if overheating blew the head gasket or if the rings went? I did compression check on front two cylinders (60 & 70 reading).
Thanks in advance.
KB
Thanks in advance.
KB
It's hard to tell until you pull the head, I just went thru the head replacement, since your poor readings are on two cylinders next to each other I'd bet on the head gasket, mine had a gap about 1/4" - a huge gap i'm sure it was on it's way out for a while, as to why it blew I don't know how to tell if it was the heat, in my case I don't think that the "people" that rebuilt my engine surfaced the head or not, it was cracked and repaired by the drill and pin method un- announced to me until I yanked the head and found it myself. I went with a remanufactured head from SOR, ordered it on a Monday afternoon and had the head waiting on my door step by that Thursday afternoon when I got home from work, so far I'm pleased- cost about $800.00 for the head and all the gaskets.and shipping.----good luck.How do you tell if overheating blew the head gasket or if the rings went? I did compression check on front two cylinders (60 & 70 reading).
Thanks in advance.
KB
