So, FINALLY finished the head gasket and did a shake down 80 mile round trip drive today. Ran awesome for first 40 miles. Started and ran smoothly, steady 187 degrees. No leaks. Let it set for 5 hours. Drove it back. When I started it, I noticed a small rattle, like a piece of trim was loose.
At the end of the drive, it had a pronounced knocking noise but was still running very smoothly. Tried to narrow it down with a stethoscope and loudest noise seemed to be power steering pump.
I pulled 1, 2 and 3 plug boots and no change. Belts are new Toyota. New idler pulleys, new alternator. New non-ratcheting chain tensioner. Head professionally serviced while off. Replaced power steering lines and installed aftermarket cooler in place of paperclip. Engine oil at full mark on dip stick. New Motorcraft filter. New water pump. Fan clutch new in last 5000 miles. New fan. No bottom end work when head was off, just cleaned block deck and piston tops. Crosshatching was still visible on cylinder walls. No scoring.
I attached a link to the YouTube video that shows idle to 3000 rpm.
I have not driven the truck since November. I am beyond frustrated. Thanks for any insight anyone can provide.
