HDJ81 Service Intervals (1 Viewer)
Abbotsford, B.C.
I've started a new thread, as my last one was probably titled incorrectly. I'm looking for the Toyota recommended service intervals for the HDJ80/81 4.2 turbodiesel. That's the schedule that in most cars is included in the owners manual but apparently for the landcruiser is not. These schedules include all recommended services for engine, drivetrain, fluids, and the rest of the vehicle. I've read this whole forum, searched, and searched the net, all with no success. This information is NOT in my Ellery manual. I did get a link to a manual in french, but the link is not working. I would also be very interested in a link to a PDF or similar for the owners manual which again I have not been able to find other than in Japanese which does not help me at all. Is there anyone that can help out? Some of the answers were helpful but not complete.
Toyotas are bullet-proof, you never need to maintain them, thats why you can't find any scheduals :D
I have never seen the factory recomended intervals, however many people here have set up their own intervals that probably work better than the factory intervals.
IMOP
5,000 kilometers Oil, Oil Filter, Fuel Filter
Check your axles oil .. for watter and change it if is necesary.
10,000 Kilimeters ( all in 5k plus ) change my diff oil and tranny and t-case if is necesary.
40,000 kilometers PS fluid, brake fluid, cooland, check my brake pads, AC system, belts.
holy crap, that is pretty intensive maintainence.
i go 5000 km (or every spring and fall if i don't put that many km on) oil, filter, check air filter.
air filter as needed
fuel filter when i buy a unit and then once a year after that.
diff fluid changed when i buy it then only if contaminated (very seldom does my trucks see many km...
check the drivetrain every sping and fall
bush truck:
change oil every 5000 or spring and fall or when contaminated.
change diff fluid when contaminated
change air filter when needed
brakes when noisy
ujoints after each muddy run
drivetrain every spring and fall or when damage or contamination is suspect
parts bush truck:
change the oil, check it over when i buy it then beat it till something expensive breaks then strip it for parts or until i need a part from it...
