Yep we were lucky to get that public meeting in before Armageddon set in. I have enjoyed my HAM experience so far and even with my limited equipment I was able to get 104 contacts during the Va QSO party last weekend.Gotta say, glad we got this done when we did
I have a few handhelds sitting in chargers in my work room and garage, I leave them tuned to a local repeater which has a Weather and Info Net every morning at 8:30.
Traffic is certainly picking up as this pandemic accelerates, more and more check ins....
I listen on the 70cm: 442.250
Nope, the LED will add a few Khz to the frequency and you won't be able to tune in. And, if you mange to tune it, it will give you fake news anyways...
Way to go....Yep we were lucky to get that public meeting in before Armageddon set in. I have enjoyed my HAM experience so far and even with my limited equipment I was able to get 104 contacts during the Va QSO party last weekend.
With the following line:I received my Handheld today... and I could use a mentor to help me learn more about operating as a HAM. My first task... honestly... is to connect to a Tysons Corner repeater and make first contact. Any volunteers?
So... I believe I heard Morse code from the repeater. It transmits in Morse its callsign. I am going to call that a win. And thank you!Receive freq is 146.91
transmit freq is 146.31 (.6 negative offset)
no CTCSS (PL) is necessary.
if you do a momentary (1 second) transmission, if you are in range of the repeater, you will here the repeater transmit for a few seconds.
Repeaters in the 147 MHz have a .6 positive offset
Are you available right now? I can try to hit the Tysons repeater from my HT.Still no first contact... but managed to successfully connect to a Tysons Corner repeater and a Vienna repeater on two separate bands each. Apparently, no one wants to respond to my dulcet tones and the sultry sound of my callsign.
Also... thinking about joining Vienna Wireless Society... anyone work with them before? Any other Ham clubs they like?
I am monitoring 146.910 right now...Are you available right now? I can try to hit the Tysons repeater from my HT.
Mitch
CLCC , We have established contact! Good job Mike.I am monitoring 146.910 right now...
qrznow.com
Well, is not that simple. You ill need to have the capability to stick an antenna up high somewhere, remember when it comes to antenna height is might..then, you need the equipment, and then, you need someone ( paging doctor EdWe should put up a CLCC repeater. How tall and how much wattage would we need to cover most of the club listening area? Also, how much would that cost? Obviously location would be a factor too.
