Was reading a thread and someone mentioned H55s are "stiff + notchy". Is this true of all H55s? Is that a bad thing??
Thanks.
Thanks.
Thanks!I’ve seen a lot of people complain about that. I don’t think they drive their trucks enough. I think we’re all used to broken in 100k h42f’s
I’ve put 33,000 miles on my new h55f that we installed in august 2018. It’s feeling broken in and not notchy like early on. My reference was the 300k trans that came out, but that’s not apples to apples. I noticed notches, clicks and whining for the first 5,000 miles and they went away. The first fluid change showed me how much metal was on the drain plugs, so the wear in period will take a while.
What @FJBen said.My H55f has almost 325,000 miles on it and still shifts fine. 1st to second can be notchy or slight grind if try to fast shift. I'd say you won't have a problem knowing you are in a gear. Nice positive engagement into the gears.
Mine does even when slowly shifting when cold. Once warm I have no problem, though more often than not I start out in 2nd gear. 1/3 synchro is on its way out though so with any luck I'll be able to tackle a rebuild this summer with new bearings, seals and synchros along with a low range gearset for the tcase. Pressing bearings on and off of the mainshaft should let me really take advantage of my new 20 ton press lol.What @FJBen said.
H55 does not like nor does it enjoy sped shifting from 1st to 2nd.
Mine has about 800 miles. It loosened up a bit after the first hundred miles.
I’d buy on again in a heartbeat. I only wish reverse was synchronized.
Well said on being cold.Mine does even when slowly shifting when cold. Once warm I have no problem, though more often than not I start out in 2nd gear. 1/3 synchro is on its way out though so with any luck I'll be able to tackle a rebuild this summer with new bearings, seals and synchros along with a low range gearset for the tcase. Pressing bearings on and off of the mainshaft should let me really take advantage of my new 20 ton press lol.
I think it’s the added linkage for the 5th gear that is “notchy by nature”. LolI've had two H55Fs and both are/were notchy. The first was used and rebuilt and shifting was notchy. Second I bought new and it now has around 150k miles on it, still notchy.
I changed my driving habits based off of this info a while ago and noticed an increase of "smoothness" in my 5pseed shifting. Great info.Also, knowing this helps tremendously. I’ve never heard anyone on the forum mention shifting speeds and rev matching. It helps soooo much. When I’m shifting from 2-3 and 4-5 I push the rpm a little harder than 1-2 because there’s a split second more time to shift at an angle than straight down. This allows the transmission and engine revs to drop down to the appropriate rpm shift range.
View attachment 2654070View attachment 2654073View attachment 2654072
Same here. Well, I did it with the 4 speed and I think it helped prolong the life until I swapped to the 5. Double clutching helps a lot too. A lot. And it’s fun. Makes me feel like Steve McQueen...I changed my driving habits based off of this info a while ago and noticed an increase of "smoothness" in my 5pseed shifting. Great info.
Double clutching is also a hellacious leg workout in these rigs in traffic....Same here. Well, I did it with the 4 speed and I think it helped prolong the life until I swapped to the 5. Double clutching helps a lot too. A lot. And it’s fun. Makes me feel like Steve McQueen...
